pressure washer and car wash
I am thinking of getting a pressure washer to clean all the masonary surfaces around the house. Is there any use washing a car as well. I know at full power it can damage and dent the car. But would you be able to adjust it low enough to blast off brake dust etc?
Well, there have been some threads on this forum about pressure washers and I myself have been doing some homework. If you are a good distance from the vehicle you shouldn't have to worry about denting and other painted related issues. Most people that I've talked to on autopia use the Karcher system with a foam lance attachment and get some really amazing results. Even though many people complain about broken hoses and leaky connections with Karcher brand items I think there are some good solutions that people have posted on Autopia to remedy the problems. Take a peak for yourself
http://autopia.org/forum/detailing-p...sick-foam.html
http://autopia.org/forum/car-detaili...ressure+washer
I've got a Karcher pressure washer, and I love it for use on cement, brick, siding, yada yada. I've just never seen the need for automotive use. I know I'm in the relative minority on this, but I'm not much on high-pressure anything when washing cars. The only exceptions I can think of would be in harsh enviromments - clay/mud or slush/salt, for example.
Side note - I've been using foam guns more and more for presoaking, and I've really come to appreciate their value.
Hi there I am going to buy a washer but due to the expense I cannot afford the foam gun until later (it's $80). Do you think the siphon detergent option built into the unit can be used to presoak the car for now..
will it do a better job than my Mr Clean dispenser gun![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
Also is it true I am just going to push the dirt into the wax/clear coat if I was a pressure washer for a quick wash, without mits
Use the "high" setting for wheel wells, mud, rims, tires. Then use the low pressure as your foam gun.
