Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
Tutorial: DIY "Black Pearl" style Emblems
Old 07-07-09, 08:13 PM
  #76
PureDrifter
BahHumBug
PureDrifter's Avatar
Originally Posted by Phiber
I tried painting mine but it turned out black. Is it because I did too much coats?
yep, too many layers. also, make sure to spray 12-18inches away.
Old 07-09-09, 09:03 PM
  #77
Phiber
Phiber's Avatar
Is there any possible way to remove the pre-existing coat and start from scratch?
Old 07-10-09, 01:45 PM
  #78
PureDrifter
BahHumBug
its a plastic emblem, if you wanna strip the chrome off it (which you WOULDNT want to do if you want to overlay with the RC Car paint) then you can just sand it down for some nice grey/black plastic.
Old 07-21-09, 11:44 AM
  #79
Phiber
Phiber's Avatar
I meant if I painted it too dark and want it lighter. How do I remove the Tamiya paint and start from scratch again.
Old 07-21-09, 01:15 PM
  #80
PureDrifter
BahHumBug
sandpaper? or MAYBE a very very light application of paint thinner that's immediately neutralized.
Old 07-21-09, 03:20 PM
  #81
felixsc300
felixsc300's Avatar
My friend and I recently redid the emblems on my SC. They were really bubbly, so he just pulled it off and sprayed some brake cleaner on it, then sanded off the paint. The paint was easily stripped off.
Sandpaper alone should do the trick too.
Old 07-22-09, 11:43 AM
  #82
PureDrifter
BahHumBug
pretty sure sanding would get rid of the chrome finish.
Old 07-22-09, 11:50 AM
  #83
YeA 2jZ
YeA 2jZ's Avatar
from your original post when you did them how long have they lasted ?? any recent pics
Old 07-22-09, 12:06 PM
  #84
PureDrifter
BahHumBug
the V8 badges on the side of the car are in perfect shape, the front badge i did didnt hold up as well, after about a year and a half it was pretty chipped up, so i would recommend some HIGH QUALITY clear coat to hold up to the beating
Old 07-26-09, 12:29 PM
  #85
Maria
Maria's Avatar
ok..well I don't own a lexus I own a Nissan Altima coupe but I really found this thread useful..I'm a beginner at all this car stuff I don't know much but I read this and decided to try and do my emblem on my car just to try it out I used the little z of my 2.5 altima
I only put one coat cus it seemed to darken it a lot is it gonna dry up lighter? and if it does can i just put some more paint on it
Old 07-26-09, 05:24 PM
  #86
PureDrifter
BahHumBug
do REALLY light coats, you probably put too thick a coat on.
Old 08-13-09, 01:39 PM
  #87
PushinLEX
PushinLEX's Avatar
great thread!!!
Old 10-02-09, 02:06 PM
  #88
sway162
sway162's Avatar
Bump...because I vote for this to be a sticky! =)
I ordered the Tamiya paint on Monday...came in yesterday and I did a test spray on my winter wheel center cap. Wow...results were perfect.
Thanks PureDrifter for creating this thread. I plan on painting my front "L" emblem to match my rear OEM BP. I will post pics when I'm finished.
Old 10-04-09, 01:55 PM
  #89
PureDrifter
BahHumBug
hahah thanks. make sure to use adhesive promoter+clear for the front emblem.
Old 10-05-09, 04:14 AM
  #90
SteadyEddy
SteadyEddy's Avatar
Location: Formerly Easton, Pa. Bradenton FL, now Osprey Fl.
For the question of how long it lasts? I did the same thing last July 08 on a chrome license plate (metal) frame for the rear and chrome license fastners (plastic) w/decorative caps. I didn't clear coat them. They still look as good as when I did them. I did this to match the SC black pearl emblems and the matching license plate frame was just too expensive. You can apply as many coats as you want to try and match the emblems.
I also cleaned the parts with rubbing alcohol to take off any dirt, oil & finger prints before painting. I also put them on a cardboard box to hold them as I sprayed and to carry outside to dry in the sun.
Quick Reply: Tutorial: DIY "Black Pearl" style Emblems
