california duster
california duster
so guys I got a california duster but i see that everytime i use it to dust the exterior of the car , it seems to leave streaks on what ever part I used it ... I let it dry in the sun like the instructions said but it seemed to make no difference at all ... dusting seems to be making the car looks worse ... any suggestions ? am I doing something wrong ?
Also its best when you use it early in the morning or late at night. Basically when the paint isn't hot otherwise you can melt some of the wax on the duster.
BTW, since I have a black car, my dash and panels gets dusty quite easily. I use the mini duster for interior and it works great!!!
Try dusting your car in the late afternoon. If theres any dew or condensation on your car, it will smear. Dont apply too much pressure when dusting. VERY VERY light feather dusting is all thats needed, anymore and scratches and smearing problems will become evident.
How much parafin wax are on these things? I've been doing it for three days straight while flipping it on all sides and it still soaks the newspaper. Is this an important part of the duster? They put so much that it seems like it's an important part of it that shouldn't be taken off or is it there for another reason?
It sometimes has quit a bit, if you have done the newspaper thing for a day or two then that's good enough, you just want to remove the excess. Once you start using it the dust will stick to the fibers and soak up more of the parafin. It may streak here and there but after about 5 good uses you should be okay.
Like others have said, best to use it when the paint is cool (less streaking) and just lightly dust the car. I have seen some use those like you would a scrub brush and it's just not meant to clean a car that has gone 7 days without a wash and parked outside the entire time.
Da Duster
Hello all,
I just recently bought a Cali car duster and love it. Sometimes it gets super dusty out here in SoCal and this thing helps out ALOT!
The question I have is that some people say good things and some say bad things about this product. Some say it scratches the paint causing it to do more harm then help. Is this true........
If this is the case I will stop using it immediately and would anyone have an alternative solution?
My California duster has been in service for a good amount o fyears now, I hear it gets better the older it gets.
However it seems like mine just pushes dust around now. Time to get a new one or can I do anything to it?
