Cleaning Mufflers
I have a gs400, and it has about 127K miles on it. I don't think the previous owner ever cleaned the mufflers. They're full of dirt, dust, grease, tar, whatever else you can think of.
What are/is the easiest way(s) to clean mufflers to bring it back to its' original shine?
I would first get some degreaser and use that to wash out the muffler, that should get rid of all the greasy and nasty stuff then pick up some metal shiners from autozone or pepboys and use that to get the shine back.
Use metal polish. But it's going to be tought to make it look new again. If you have a dremel, you can use a polishing wheel with metal polish. That will be more effective than using your hands.
Ooooorrr..you can go with an aftermarket exhaust like I did and not have to polish that often. In fact, I just wipe it down with my car soap and its clean
Just get some metal cleaner and some scotch pads or steel wool. That will take off 95% of the grime. Then use the polish again and clean it up. Should get "close enough".
3M™ Chrome and Metal Polish
$9.99
Removes surface rust, oxidation, corrosion and tarnish from chrome, stainless steel and other automotive metals such as brass, bronze or copper.
![](http://us.st11.yimg.com/us.st.yimg.com/I/rodi_1973_183317784)
Zymol Metal Brightwork Polish
$26.95
The Zymol Metal Brightwork Polish was developed specifically for your automotive vehicle. You can use it on all types of metal including stainless steel, aluminum, nickel and others, all of which are susceptible to damage by salt corrosion, engine oils, acids and other environmental exposure. Chromed and plated surfaces need to be treated gently Zymol Metal Brightwork Polish has a special blend of oils that gently remove the tarnish and discoloration caused by exposure to the elements.
![](http://us.st11.yimg.com/us.st.yimg.com/I/rodi_1973_265021687)
Mothers Mag & Aluminum Polish
$7.99
Mothers Mag & Aluminum Polish is our legendary metal polish. Mothers’ secret formula balances a brilliant shine with easy use for aluminum wheels and parts, brass, alloys and accessories. Application is just a matter of a clean cloth and a little elbow grease. Mothers Mag & Aluminum Polish is strong enough to put a shine to the most neglected metals and gentle enough to use on a regular basis.
$9.99
$26.95
$7.99
RaceCar350
RC - 1st Gen (2015-present)
06-09-17 06:56 AM
jnguyen87
03-06-11 07:23 PM
