Porter Cable 7424 Car Buffer / Polisher on sale $99.99
Check out Tools-plus, they have the porter cable buffer going for 99 dollars with 6.95 shipping!
http://www.tools-plus.com/porter-cab...m_term=P-C7424
I think I am going to go ahead and go with this deal. Does this sound like a good deal guys? I am new to electric polishers, this model seems like the best bet to go with a beginner and is even a good model for experienced detailers who don't want to use rotaries. I want to remove swirl marks and stubborn water spots mainly and some minor scratch correction if it is possible with this orbital. Are there any better orbitals out there that you guys would recommend over the 7424, seems like the 7424 is by far the most recommended and common orbital but maybe there is a new model that is a little better. Any recommondations on polishes and pads, whats the best deals and where to get them?
I have done a little more research and looks like I should get a hook/loop backing plate for ease of changing pads and that I should get a compounding pad for minor correction. I read mixed reviews where the 7424 may not be good at removing minor defects(swirl marks, oxidation, water spots, fine scratches) and either can't or more or less just make them a little less noticeable and they will come back after a few washes but others say it does a fine job as long as they are not too deep and they are very happy with its performance.
I saw where some where highly praising the Makita BO6040 2 mode where it offers the best of both worlds, orbital motion for safely applying/taking off polish,wax,etc and safe minor corrections and also can be switched to rotary for quicker applications and correcting/removing more serious defects that a orbital is unable to. Unfortunately it cost over twice as much as the Porter Cable and I have not heard too much about it.
There was also a model called a Flex XC3401VRG dual action polisher that is supposidly superior to the 7424 action in correcting defects but safer then a regular rotary. Again it costs over twice as much as the PC and I have not heard too much about it.
Anybody have any experience or more info about these models, is it better just to spend extra and go with one of these 2 instead of the PC which might not be able to do much for swirl marks, waterspots, light scratches, etc from some of the things I have been reading where I might need to eventually get a rotary or one of the above models for correction. I still think I might just go with the PC as that is a great deal and I have no experience with rotaries on vehicles, I just don't want to waste money on something that is not going to do much better then a 30-50 dollar sears polisher at correcting any blemishes.
I have used all 3 machines and really like the Flex. But, just to clarify, the PC is a random orbital polisher, the Flex is a Forced Rotation (not rotary) polisher, and the Makita BO6040 is a combination of both. Festool RO150FFEQ is also a dual mode and the best machine in terms of orbital as well as forced rotation. None of these machines will replace a rotary buffer, but the forced rotation polisher will do much more correction than an orbital.
Depending on what kind of correction you are trying to accomplish, my recommendations may change. For minor swirls, fine scratches, and light paint cleansing, the PC is fine. It is economical and is the least damaging.
The Makita BO is heavy and the power switch is a little hard to find, especially when you need to turn it off fast. The Festool also has a switch, but its located on the top of the machine, so its a little easier to switch on/off. The Festool is also the lightest (about the same weight as the PC) of all machines, but is also the most expensive ($440-$500).
The Flex and Festool have the most correction ability, but the Flex has a trigger which allows variable speed and power. The Flex is very ergonomical and is priced at about $280, the same as the Makita BO. But, the Flex is very popular now and might be a little hard to find until late Jan/early Feb.
Hope that helps.
Hope that helps.
Hope that helps.
Hope that helps.
High speed buffers are dead technology, the create swirl marks no matter how good you are. The only difference between people who use them are if they can move the swirls to the right place or not. Plus you run the risk of burning through the paint!
Use a Cyclo Dual Head. Just as fast (3,000 Orbits Per Minute) And 10x as effective. You can leave it in the same spot for as long as you want and it will never burn the paint.
Couldn't believe I ever even touched a high speed buffer.
1stgenGSb
Automotive Care & Detailing
07-28-08 02:55 PM
