Is there a cleaner GS headlights
Theres a sticky at the top of the forum about restoring old headlights, why not follow it? Heres another good write up, http://audizine.com/forum/showthread.php?t=181134
It isnt necessary to just replace the headlights. PM me if you need someone to do this for you. I know someone in FL.
Check out detailman's link, I did the same thing to a friend's headlamps. Very easy, the hardest part may be finding a rotary polisher and wool pad.
If the lamps are that bad you may just try the plastx and a rotary first, then try the sandpaper.
