Polishing Question
#31
thanks tod for the great help!!! how many coats of wax do you use actually? I read in autopia forum that for a deeper gloss, 2 coats of wax is needed. 1st coat to dry for 24-48 hours and 2nd coat...is it true??? Also, how long of between a full wax job do you wax again?
For example:
(If i use meg's #9, then #3 and then Nxt 2.0 Wax. How long do i have to wait so that I can repeat the step again? 2 months? 3? 4 months?
For example:
#32
For example:
For example:
FWIW, pure Carnauba wax products (not cleaner waxes) usually look better with a second coat as well due to the more even coverage of the second coat.
As to reapplying, you can re-apply as often as you like. If you think the appearance has been degraded due to harsh environmental contamination, there is no reason not to reapply. You can do the fingertip test to decide if you need to reclay and use that as your determining factor. If the car is garaged a lot you might not notice any bonded contaminants but still want to reapply your polish and wax. No reason why you can't. Using gentle polishes like #80 with a PC every month would not damage your paint.
Let your eyes and fingertips guide you.
#33
Thanks Jim!! But I saw #80 has a cutting rate of 4/10 whilte #82 a swirl free polish only rated at 3/10 cutting power....So is #82 safer? Also, if you do it every month, is the wax from previous job still there? or it will be buff out because of the polish?
#34
No need to polish every month. Just wax or sealant. You can polish every 3-4months as needed, then repeat your whole process, including clay, every 6 months. If you keep washing every week, wax every month or 2 weeks, you shouldn't have to polish that often. I clay/polish mine every 6 months.
#35
You could use either product every month and not harm your paint. Both are quite safe.
Now that said, you would really not need to use a polish that often. Even in the worst environment I've been in, I wouldn't see needing to polish more than once a quarter. Yet, you never know what can get on your paint. You just needn't worry about overusing either with a DA polisher.
Every time you polish with an abrasive product or use clay you will be removing the wax or sealant.
Like tod071 suggests, you likely only need to clay and polish every 3-6 months or so. If you use UQD after your washes and/or reapply NXT every month or two your car should look great all the time. It also helps if you garage your car at night.
#36
AND...
I live on oahu, tod071 also lives in oahu so if i fk it all up i can call him up to bail me out of my stupidity. BUT after 8months of doing it my way and not having any isssues... as i said before, it works for me.
#37
thanks guys...i guess i just have to buy all the products now...
Tod, when you say wax every 2 weeks or a month, do you use the NXT wax or just the quick detailer/wax that every1 uses after a car wash
#38
I wax every month. Its all personal preference, so its really up to you. There are alot of factors that may diminish your durability, so you may need to wax more often or not.
#40
I see!!! anyway...since im using mostly meg's product...should i buy meg's pads or Lake Country pads for my PC??? Also any difference between the 2 pads??? Which better which not?? anything like that???
#41
Can't go wrong with either.
