View Poll Results: Do you condition your leather seats?
Yes I do
167
64.73%
No I don't
37
14.34%
Thinking about it
54
20.93%
Voters: 258. You may not vote on this poll
Do you condition your leather?
#91
To dispel the theory that if your leathers are coated they will not absorb a conditioner, I'd suggest you actually try this test. In an inconspicuous area, put a drop of ink. Let it set for several minutes and wipe it off. Now try and explain away that inkspot as the leather won't absorb anything because of the coating.
The polyurethane coating is permeable.
That said, the most damaging effect to leathers is caused by dirt. Keeping your leather clean will increase it life. You can use any of several leather cleaners on the market or use something like Woolite/water (1:20 ratio) and clean your leather frequently. Don't over wet the seats when cleaning and be sure to wipe with a clean damp cloth to remove any detergent residue, then buff dry with another clean MF.
Lexus recommends:
Conditioning will replenish some of the oils that evaporate as the leather ages.
Cleaning and conditioning will help to keep your leather softer and less wrinkled over time. You probably only need to condition a couple times a year.
You might also wish to read the sticky "All about Lexus leather" in this forum.
https://www.clublexus.com/forums/sho...d.php?t=115497
permeable |ˈpərmēəbəl|
adjective
(of a material or membrane) allowing liquids or gases to pass through it
adjective
Lexus recommends:
1. Wipe it off lightly using a soft cloth (e.g. gauze) dampened with 5% solution of neutral detergent for wool.
2. Wring water from a clean cloth and thoroughly wipe off all traces of detergent with it.
3. Wipe off the surface of the leather with a dry soft cloth. Allow
the leather to dry in a ventilated shaded area. Excess of wet may cause the hardening or shrinking of the leather.
#92
+1 i love my lexus but i hate the seats i hate the leather, in my merc and in my audi the leather is fantastic nice thick and firm my a4 has 100k and leather looks new my merc has 30k and it looks new and so have all my previous merc's on my lex i have 30k miles and its begining to look like poop i am thinking about get new oem seats actualy.
The older Lexus leathers like on the LS400 are not treated with this horrible protectant and can be cleaned with more aggressive cleaners and softened with Leatherique. More aggressive cleaners like Fast Orange and Soft Scrub used on newer Lexus leather will start taking the dye off for some reason.
I have read some places LeatherMasters conditioner/softner may work a little better then Leatherique but very few people have used it so I am a bit skeptical .
#93
#94
You're confusing staining the polyurethane coating with permanent ink with actual absorption by the leather. I can get ink to dye a clear bra on the front of my car as well...doesn't mean I'm staining the surface of the paint underneath. If you don't notice color shift in the leather as a result of applying a "wet" product, it isn't absorbing it - period.
The polyurethane coating is indeed permeable.
#96
I've had cars with leather seats before, and if you don't condition them, they leather can dry up and crack in time. Also, UV rays can damage leather if it is not condtioned regularly.
#97
I don't believe that is correct. I have cut a piece of leather from under the rear seat, marked it with ink and then scrubbed the ink blot with a magic eraser until the coating was removed and the ink stain was still in the leather. I tried this on the light tan color leather. After scrubbing, the coating off, the leather was a darker tan color and the texture was also altered so I know the coating was removed. Yet the ink stain was still there in the leather.
#98
FWIW, here is what the supplier of our Lexus leather recommends.
Automotive Leather Interior Care
GST AutoLeather automotive leather interiors are designed and crafted to look good and stay that way. But like any natural product, leather requires some care to keep looking its best.
Here are a few tips to follow to make sure your automotive leather interior holds its value for the long-term:
Clean up spills immediately.
Don't give stains a chance to set on your automotive leather interior.
Use a mild cleaner.
Choose a mild soap and use water to clean your automotive leather interior. Or use a damp rag or sponge to clean the surface and concentrate on small areas at a time. Don't saturate the leather with water.
Use a leather conditioner.
There are many fine products available that can improve the softness and texture of your automotive leather interior. While we don't recommend any one in particular, we suggest you drop by your local auto parts store for their advice.
Use a foldout sunscreen.
If you live in a hot climate, your automotive leather interior can age prematurely when exposed to excess heat and light. Tinted windows or a foldout sunscreen can help you protect your automotive leather interior.
Use professional detailing services.
If you're like us, you spend a lot of time in your car. Periodically visit your local automotive detailer. They carry products designed specifically for your automotive leather interior not available to the general public.
Use a mild cleaner.
High-End Luxury
This is the highest quality leather, normally reserved for luxury SUVs and sedans. This leather is known for being natural, soft, and lightly coated. Leathers in this category include Aniline and Semi-Aniline. The light coating improves the light fastness performance.
windfall12
Automotive Care & Detailing
15
08-24-07 01:36 PM
