favorite clay bar?
I've been claying my car slowly when I have time, and I'm trying to get all the little specks out of my paint. My car is a 98 and is pretty old, but it seems like the car has never had a proper detail. So far I've gone through a Mothers clay bar, some gray clay bar I had (I think it was 4 star, but I can't remember), and I've been doing the little spots with pinnacle poly-ultra clay.
The mothers clay got dirty fast and had to be trashed, so I tried the the gray clay after and it was a lot more aggressive, and the car was much smoother after using it, but the little brown specks can be seen when looking at the paint closely. I've been doing little patches with the pinnacle clay, and it has been pretty successful except for a few tough spots. The pinnacle is easily my favorite clay to use, but it requires some force to remove the specks in the paint, and I'm getting tired of claying the car, so I was wondering what brand of clay do you guys like to use?
How often are you claying? It sounds like you are claying way too often. But it seems like you're not happy with the results of the clay you've used. I'd go with Clay Magic Claybar (Blue). Its very sticky and needs to be well lubed, but very effective. I haven't had to use anything more aggressive yet. Certain defects may need to be worked harder than normal.
Yeah, the claying has been a bit excessive, but all of that was done within a time span of a week or two since I only work on the car when I have some time to kill. I didn't even finish the full car with the mothers clay before I had to trash it, and then I followed up the whole car with the gray clay to get it all smooth. After that I've been doing certain spots with the pinnacle clay.
Anytime you clay, it will remove any protection you already applied. So, you should protect it with wax/sealant after every clay. Otherwise, you're driving the car unprotected.
I might just settle for how the car is now, and start the polishing process, and then finish it off with a sealant and wax.
Hacked CL to become a Mod
i use mother's too...but it's so expensive and so small (talking about the yellow ones) i clayed my car not too long ago but since i saw nothing on the clay itself i stopped doing it. usually i use paint sealant after clay and wash...makes life a lot easier
Cycle Savant
This past weekend, I used Maguire's Smooth Surface Clay bar with detailing spray wax, and then finished with polish wax. The kit came with the clay bar, spray wax, polish wax, and microfiber towel; all for about $17.
Use it on both the car and the motorcycle this weekend.
I highly recommend it for ease of use, cost, and excellent results.
I started with the mothers kit but I never used the other stuff that came with it, good clay though. Right now i've got a supply of Sonus clay i've been using and it works just as well. Didn't like the zaino clay.
I've used meguiars clay. I really really really really hated it. It was brittle and soft. I detailed Dung0981's white GS and even he agreed it sucks. Can't tell you how many times I have to reform the clay because it was breaking into pieces. Apparantly I'm not the only one who shared this experience. Many on autopia had the same problem.
Clay magic is my choice when it comes to easy replacement and effectiveness. Other than that, I'll steal some Pinnacle from Blkexcoupe's house
Sorry but the clay bar does not remove wax/sealant only the contaminants that sit on the paint.
Cycle Savant
It was frustrating at first (I wiped off the spray the first time, instead of using the clay while it was still wet), but as soon as I got the hang of it, it turned out well.
