Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
Can someone please help with glass cleaning info
Old 05-30-08 | 08:35 AM
philES300's Avatar
philES300
Default Can someone please help with glass cleaning info
I have a 97 es300 and the one thing I've always had trouble doing properly is cleaning the windows, in and out. Can anyone please give me any quick tips (what kind of cloth to use etc) thanks
Old 05-30-08 | 10:43 AM
The Detail Dude's Avatar
The Detail Dude
Hi Phil,
I would recommend our Glass Cleaner. It does not streak and smear all over the glass. We formulated it with enzymes that actually cut through grime and leave the surface....well, as clear as glass.
Old 05-30-08 | 11:02 AM
smoothLEX's Avatar
smoothLEX
I use Stoners Invisible Glass. It's probably the best window cleaner I've tried.
Old 05-30-08 | 02:31 PM
eyezack87's Avatar
eyezack87
Stoners or Sprayaway Glass Cleaner are good choices. I usually take NXT 2.0 with my PC and spread it on there so I get some cleaning and protection as well. So far it works quite well
Old 05-30-08 | 03:26 PM
philES300's Avatar
philES300
Thanks everyone for the info. How about the best kind of cloths for glass? I'm going to check these all out, although I admit "stoner's" speaks to me
Old 05-30-08 | 05:12 PM
jfelbab's Avatar
jfelbab
Default Glass Cleaning 101
I've cleaned a lot of glass and have found two OTC products that are superior at cleaning oil and film. The first is Stoners Invisible Glass. The second is Meguiar's NXT Glass Cleaner. When used with short nap micro-fiber towels they provide excellent cleaning with streak free results. There is a third product I'll mention that is extremely good but it is only available from Meguiar's direct. It's their Detailer Line Glass Cleaner concentrate. This gallon of concentrate gets mixed with water at 1:10 ratio. So the gallon turns out 11 gallons of a most remarkable cleaner. For those who detail a lot of cars this is worth getting.
Some Do's and Don'ts.
• Do clean your windows in the shade when the glass is cool.
• Do use a microfiber dampened with the glass cleaner and wipe dry with a separate dry miocrofiber using light strokes until the glass is dry and slippery smooth. If you feel any drag on the dry towel, the glass is not yet clean and you need to redo it until it feels slippery.
• Do use a product on your interior dash and vinyl that doesn't emit a lot of film or oil vapors. I use Meguiar's Quik Interior Detailer. It isn't shiny, provides UV protection and doesn't seem to outgas.
• Don't use a glass cleaner with ammonia in it. This will leave a film and ammonia might just ruin a tint.
• Don't use newspaper. This used to work back when the newsprint was printed on high rag paper with real inks. Today they will usually just leave oily streaks. Microfibers work much better.
• Don't let your microfiber towels get anywhere close to any cotton towels. MF towels draw up cotton fibers like a damp sponge draws up water and you will have a major lint problems with them forever after.
These products and microfibers work well on both the inside and outside. Occasionally you might find that the exterior glass might need more agressive cleanning. When I detail a vehicle, I begin by washing and claying. After claying the paint I clay the exterior glass. Clay will safely remove a lot of really tough road grime on the glass, especially the windshield.
Some newer vehicles come with a permanent water repelling coating on the side glass so be sure you know what your are doing before using any abrasives on this glass or you will damage this coating. Using steel wool, for example, will cut right through this coating.
I've also known people who wax their glass but I've found that this usually causes poor visibility at night in the rain.
Glass is hard and doesn't need wax to protect it unlike your paint. Wax clearly degrades over time and especially under harsh environmental pollution and sunlight. Why put something on your glass that will degrade your visibility. It's simply not needed. If you want the water to rush off the glass it's probably better to use a product designed for glass like RainX or Aquapel. I prefer clean glass as any coating you put on the glass may cause wiper chatter or visibility issues.
Old 05-30-08 | 05:15 PM
13loody's Avatar
13loody
I use SprayWay glass cleaner with a microfiber towel. I actually use the $15 35pack of yellow general microfiber towels at Costco, which is where I picked up the SprayWay as well. I believe the SprayWay was less than $8 for a 4pack.
Old 05-30-08 | 07:29 PM
samathews's Avatar
samathews
I like Surf City Glass Cleaner - Stoner's works well too. Clay is a good idea if you some built up grime. There are also glass polishers - autoglym is one that I use.
Old 05-31-08 | 06:50 AM
ArmyofOne's Avatar
ArmyofOne
Dysfunctional Veteran
I agree with all of this except for the waxingt he glass part. I agree that it isnt nessecary, but i have waxed my windsheild literally for YEARS on every car i have had and never had a visibility problem in ANY weather, unless it was from the weather itself. I have tried rainX...first 2-3 rains it throws deuces (meaning its not there any more), but just putting meguiars gold class paste wax on the windsheild, i get about 3 months before i have to do it again. I use meguiars QGDT on the glass to clean and maintain my wax coating after i wash. I tried a similar product from turtle wax, but it took the wax off and left my glass with a "sheeting effect" while the rest of the car beaded...heh...not cool.
the only way you have a visibility problem, is if you didnt get all the haze off. at times in the rain on the interstate, i dont even have to turn on the wipers, and a few times at night it took me a second to realize it was even raining.
Old 05-31-08 | 01:51 PM
philES300's Avatar
philES300
Wow thanks everyone, and especially to jfelbab for taking the time to write that out for me. I have everything i need to know then for some beautiful glass.
Old 06-05-08 | 03:36 PM
MrG4Life's Avatar
MrG4Life
CL Folding 100000
So after seeing many of their ads in my car magazines AND reading the opinions of a few here, I went out and bought Stoners Invisible glass cleaner. This product is amazing but gotta question. Normally when I clean my windshield, I apply Rain-X on it. Last weekend when I put the Rain-X on the glass, I didn't do it right this time because my windshield ended up looking hazy. So I bought a can of Stoners and my windshield has not looked so good since I first bought my ride. Now to my question. The last two days we've had some heavy rain. On the highway, the water was beading away off the windshield. Does the Stoners also make rain bead off the glass or is that perhaps leftover Rain-X solution that still may be on the windshield? As far as I know, it's a cleaning solution.
Break2
11-09-17 10:33 AM
sydtoosic
15
09-28-13 08:34 AM
jfelbab
13
11-21-09 12:26 PM
biff44
08-05-07 11:54 AM
Seattle SCone
09-02-02 08:33 PM
Quick Reply: Can someone please help with glass cleaning info
