Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
Clear Coat Got On My Paint!
Old 07-01-08, 12:35 AM
NODNARl3
NODNARl3's Avatar
Default Clear Coat Got On My Paint!
So my brother has a Honda civic and he took out his emblems to spray paint and clear coat the emblems. However he was doing it pretty close to my car, not that close, but as he was finishing up by clearcoating, when he sprayed it, the wind blew the clear coat to the front of my car next to my grills. and now the front looks like a piece a crap,but he tried to get napkin and tried to remove it but it smeared all over. What can i do to remove all this??
Old 07-01-08, 12:44 AM
Fizzboy7
Fizzboy7's Avatar
First try a wax or wax-cleaner. If that doesn't do it, you'll have to have the area clayed.
Old 07-01-08, 01:02 AM
kuuqi
kuuqi's Avatar
claybar will get it off easily. make sure you go on youtube to look at claybar videos to know how to do it properly
Old 07-01-08, 05:40 AM
Copper_Hed
Copper_Hed's Avatar
http://www.meguiars.com/estore/product_list.cfm?sectionname=Consumer%20(Meguiar's%20Brand)>Auto%20Paint%20Care>Auto%20Detailing%20Clay&sectionID=11201
This works pretty good. I repainted the lower trim on my Trooper, everything was masked at least 24", paint was OK but the clear did aerate and overspray even with my HVLP gun. I will be sure to bag the vehicle next time!! Anyway, this product worked for me.
By the way, did your brother get out of the hospital yet??!
Old 07-01-08, 07:05 AM
SpecC
SpecC's Avatar
your worse case scenario is to wet sand. i'd avoid it though. Maybe you could try heating it up a bit and claying it
Old 07-01-08, 09:54 AM
Scheersped
Scheersped's Avatar
i would just use clay. the CG gray clay has never failed me when it comes to taking off overspray. if that doesn't work, try a more aggressive clay like the purple.
Old 07-01-08, 11:10 AM
tod071
tod071's Avatar
You can clay it with Clay Magic clay or any other claybar kit OTS. Just remember to keep the surface well lubricated with a quick detailer or car shampoo.
After you're done with the claybar, because the paint will be unprotected, don't forget to protect it with a sealant or wax. Then send your bill to your brother
Good luck.
Old 07-03-08, 05:13 PM
khooper
khooper's Avatar
Now that it's dry you might be able to remove it with some buffing compound (and a lot of work). Failing that, I believe it does look like a trip to the paint shop.
_____________________
Check out my Interstate
Nidimob1
10-15-14 07:12 PM
Zizi250
06-21-14 10:58 AM
TerrySmith
03-25-13 02:04 PM
schase8
08-16-12 11:39 PM
tstead
ES - 5th Gen (2007-2012)
04-07-07 06:49 AM
Quick Reply: Clear Coat Got On My Paint!
