Ask GlimmerGlass
#166
Thanks Chris, After inspecting the roof, I think I can get a majority of the scratches out, but there are a few that are deep enough to catch a fingernail when dragged across them. I'll have to take some before/after photos to share when I begin the process. anything that doesn't come out, I plan on hiding with black hole glaze and 2 coats of EXP and then 2+ coats of Collinite. Steve at Poorboy's seemed to think this would last for about 6 weeks or more before needing to be re-applied. your thoughts on hiding any remaining scratches?
#167
Chris,
Any suggestions for how to get rid of a scratch/scuff mark on the dashboard (actually the glove box door) of my IS 350? It's small (about 1"), but annoys me. I've already tried Optimum Leather Protectant, and that didn't really help. Someone suggested a Mr. Clean Magic Eraser, but I'm concerned about damaging the surrounding area.
Thanks.
Thanks.
#168
Chris,
Thanks.
Thanks.
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
#169
I need help deciding which Porter cable package to purchase.I have a 93 dwp sc400 that has ALOT of swirls,but no nicks or scratches.Would the Poorboys package be good?Which pad size and type do you recommend?Also looking to buy a clay bar,but not sure which grade to buy,Ill be using it on the sc and my 2007 scion tc that has only been waxed once and washed evey few months...Sad I know,Please help lol.
Thanks,
Philip
Thanks,
Philip
#171
Thanks,
Philip
Thanks,
Philip
IMO a fine to medium grade clay bar would be ideal for your paint. Try out the Megs Clay Kit at Target, that is a fine grade bar. If it doesn't do the job, you'll need something stronger like medium
#172
Thank you,Ive read good thing about thier products.Sadly,I used to work at a nissan dealer as a "detailer" but all I did was interiors and an exterior detail in there eyes was waxing with banana wax haha.Ill try it out and post up results and lots of questions Im sure.
#173
Thanks,
Philip
Thanks,
Philip
iirc Chris is on vacation so I'll try to help in his absense lol. For the Poorboys products, I've heard very good things about them in the past. Obviously for some swirls, you'll need to do multiple hits to remove them to the point that you are happy with. Polish and machine are only part of the equation. Your determination is the main factor in the finished project ![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
IMO a fine to medium grade clay bar would be ideal for your paint. Try out the Megs Clay Kit at Target, that is a fine grade bar. If it doesn't do the job, you'll need something stronger like medium![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
There is definitely a possibility of uneven paint coatings. Easiest way to tell is with a paint meter. In terms of hardness, if its the same clear used on the entire hood, theoretically it should polish out the same way, but that may not be the case. Paint is full of surprises to say the least![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
As mentioned, the Poorboys Kit is a great choice. I consistently get positive feedback on that kit. The Optimum and Meguiars kits are both solid kits as well though. The Megs kit may arguably be able to remove more swirls based on 105 vs ssr2.5. M105 is pretty strong, but does finish down very nicely.
I would suggest going w/ the 5.5" ccs pads in either case. I find that they work much better on the PC/DA style machines. Pair the orange pad w/ the ssr2.5 (or comparable product... opt. compound, 105) and the white pad w/ the ssr1 (opt polish, m205). 2.5 worked at speed 5+ and ssr at speed 4.
As for clay, if you'll be claying a few vehicles, the 200g gray bar would be sufficient. Its the most commonly used bar and can tackle the large majority of jobs. Unless the vehicle is in really bad shape, you shouldnt really need much more than the gray bar. Luber is a really great clay lube as well.
#174
There is definitely a possibility of uneven paint coatings. Easiest way to tell is with a paint meter. In terms of hardness, if its the same clear used on the entire hood, theoretically it should polish out the same way, but that may not be the case. Paint is full of surprises to say the least ![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Is there a visual way to tell? Like, it'll look less glossy where clear is running out?
Or... what's the consequence if the clear runs out and I end up using Mezerna IP on it?
#176
Unfortunately no way to tell just by looking. Burning through clear is pretty unlikely w/ a PC. If an area were to get damaged, you'd most likely need to bring it to a shop for paint work. But again, its pretty rare for that to happen.
#178
Also, how do paint meters measure the clear? Is it just the distance between the meter and the first non-transparent material? I.e. If I use the paint meter on a spot that happens to have tree sap, would it return me the thickness of clear+sap? Or just the sap?
#179
There's a $200 one? I keep seeing like, $600 and $700 ones that connect with your computer and stuff. What's the easiest/cheapest paint meter that would suffice?
That is the best one for the price. They measure all of the paint, clear, base, primer. Only on metal surfaces though, no plastic
Sides, when you measure paint, surface is supposed to be clean lol
#180
http://highlinemeter.com/
That is the best one for the price. They measure all of the paint, clear, base, primer. Only on metal surfaces though, no plastic![Wink](https://www.clublexus.com/forums/images/smilies/wink.gif)
Sides, when you measure paint, surface is supposed to be clean lol![Stick Out Tongue](https://www.clublexus.com/forums/images/smilies/tongue.gif)
