Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
Ask GlimmerGlass
Old 09-24-08, 05:18 PM
  #106
Chris@GlimmerGlass
Chris@GlimmerGlass's Avatar
Originally Posted by UpstateLex
Chris,
since I live in a snowy area, what would you reccomend as far as prepping for the upcoming winter months? I'm definitely going to do the leatherique that you posted but what about for everything else?
Originally Posted by BounceNY
I'd like to know as well, last winter I used Klasse sealant which seems have done a pretty good job.
If I have time, I want to post up a similar post to the leatherique one, only for exterior, but I dont know if I'll have the time for it to be beneficial to everyone this year.
Anyway, in short, my personal routine is something like this:
For wheels, I do a very thorough cleaning and apply 2 coats of poorboys wheel sealant. Helps to keep the salty road grime off, or at least rinse off easier anyway when the time comes. Optimum Tire Gel on the tires.
For paint, I; clay, poliseal (or polish w/ sealant), then do collinite 845 on the truck and 476 on the M3. The 476s will actually be a little more durable since its in paste form, but I just love 845 on the truck. Collinite is definitely the go-to product on the exterior for mine and all details I do in the cold months.
Other little stuff I do is, Trim Restorer on exterior trims, and add about an ounce or two of Poorboys Bug Squash to the windshield fluid reservoir to give the washer fluid a boost. (dont use a lot though.. its only meant as a booster, not a replacement).
Old 09-24-08, 08:11 PM
  #107
BounceNY
BounceNY's Avatar
Cool, thanks for the input!
Old 09-25-08, 09:12 AM
  #108
UpstateLex
UpstateLex's Avatar
For real Chris thank you, going to be my first winter with a nice vehicle so I was in desperate need of some help. I hope you get to that write up if you get the time if not than thats okay !
Are the products you mentioned located on your website?
Old 09-25-08, 06:49 PM
  #109
kloh7
kloh7's Avatar
Curious about Klasse Sealant Glaze, since it has the word "glaze" in it. Does it mean its a real glaze? I hear it actually might amplify minor scratches in paint. I washed, clayed, washed again, polished the car and was going to use the sealant and then some wax for the paint to "pop" but now was thinking for some minor scratches I still have, should I put a glaze on and then seal and wax? Please help. Thanks in advance.
Old 09-26-08, 05:17 AM
  #110
Chris@GlimmerGlass
Yes, they are
For wheels:
Premium Blue:
http://www.glimmerglassdetailing.com/prblwhrimcl.html
APC for tires:
http://www.glimmerglassdetailing.com...dable-apc.html
Wheel Sealant:
http://www.glimmerglassdetailing.com/wheelsealant1.html
OptiBond Tire Gel (apply w/ foam applicator)
http://www.glimmerglassdetailing.com/optigel.html
Bare Bones for wheel wells:
http://www.glimmerglassdetailing.com/babounsp.html
If you dont plan to remove the wheels to clean the back sides, I'd recommend grabbing an ez detail brush to reach back there.
http://www.glimmerglassdetailing.com/ezdetailbrush.html
For paint:
Clay:
http://www.glimmerglassdetailing.com...ubricants.html
The elastic or gray 200g clay is what is most common to use. If your paint is in very good condition, you can go w/ the extra light cut bar though. LUBER or Spray n Wipe for clay lube.
PoliSeal or Polish w/ Sealant. Both very good. PoliSeal is a larger bottle, if that matters:
http://www.glimmerglassdetailing.com/oppo.html
http://www.glimmerglassdetailing.com/powise.html
Collinite 845 or 476s for wax:
845 is very thick initially. Warm it up and it becomes watery and much, MUCH, easier to apply. Do this by letting it sit out in the sun, put it under some hot water, etc.
http://www.glimmerglassdetailing.com/coaupr.html
Recommended towels: (6 of one of the following should do)
http://www.glimmerglassdetailing.com/16x16elite.html
http://www.glimmerglassdetailing.com/flmito.html
http://www.glimmerglassdetailing.com/16x16eliteii.html
http://www.glimmerglassdetailing.com/mega-plush-1.html
Glass:
http://www.glimmerglassdetailing.com/glasscleaner.html
http://www.glimmerglassdetailing.com/miglto.html
mix in a little bit of bug squash to wash fluid res.
http://www.glimmerglassdetailing.com/bug-squash.html
Trim Restorer (use w/ microfiber applicator)
http://www.glimmerglassdetailing.com/trim-restorer.html
Old 09-26-08, 05:39 AM
  #111
Chris@GlimmerGlass
Although I dont personally use the klasse products, its my understanding that KSG is not really a glaze in the traditional sense that it is oil/filler heavy enough to hide imperfections, and more so a sealant. Someone with more personal experience w/ the product may be able to give a more accurate representation of its abilities to help hide some defects.
If you want to glaze first to help hide some imperfections, consider chemical guys ez creme glaze, which is an acrylic glaze, then you're finishing products.
http://www.glimmerglassdetailing.com/exshezglwshi.html
Old 09-26-08, 04:45 PM
  #112
ItsChris
ItsChris's Avatar
hey chris, thanks for being kind enough to answer questions for us on this board, im new to the board, so I'd like to ask you a question please
I bought a gs400 and I guess the previous owner left it by sprinklers, or something. Pretty much the whole rear passenger window's and some of the passenger window, have these really nasty Water spots, i guess from the hard water.
I Tried already:
1) Fine, medium, and ruff wire metal pads - very little change with the Ruff wire pad, but was still their
2) Rubbing Compound ( Red and white) - Didn't work
3) Invisible Glass, tried like 10 coats (from other people on the forums)- didn't work
4) i tried to polish them out - didnt work
I dont know much I can do, please help me !!
thanks in advance !
Old 02-07-09, 10:50 PM
  #113
eyezack87
eyezack87's Avatar
I think its time for this thread to be bumped. My PM box is filling up quite rapidly because of detailing PMs haha. Not that I do not mind, its just that I don't want to go back later and delete all the unimportant ones when it gets full thats all
Post away people
Old 02-09-09, 09:01 AM
  #114
Chris@GlimmerGlass
Post away people
Old 02-09-09, 07:09 PM
  #115
SC34M3
SC34M3's Avatar
how can i remove water marks that been on for yrs i believe....i have used vinegar and that ain't cutting it.
Old 02-09-09, 08:28 PM
  #116
Vincent123
Vincent123's Avatar
I used vinegar and clay bar and it took off waterspots that have been on my car for quite some time. Try the clay bar if you havent already
Old 02-09-09, 08:49 PM
  #117
GS300Rich
GS300Rich's Avatar
Got any suggestions to clean a stained/faded black plastic bumper of a ford sport trac? It appears that it is either faded by sun or some sort of chemical. The neighbor who owns it was in an accident about a month ago and the bodyshop had to repaint part of the bed of the truck, and now there are parts of the bumper that have a white/gray haze. Anyway to restore it back to black to match the sideskirts? I tried cleaning with 303 aerospace protectant to see if that would do anything but it was minimal
Old 02-09-09, 09:54 PM
  #118
eyezack87
eyezack87's Avatar
As long as it is textured plastic I would recommend Black Wow to get rid of the haze and restore it back to normal black. If you are at the price for the bottle consider this, I've done over 30 cars with it and I barely touched 1oz. A little truly goes a long way because once the included applicator is saturated, I did not have to add anymore
Old 02-10-09, 05:38 AM
  #119
GS300Rich
GS300Rich's Avatar
where can I get black wow at? If it works good it will pay for itself Thank you for the help
Old 02-10-09, 09:02 AM
  #120
Chris@GlimmerGlass
If a vinegar solution alone didnt work, my next suggestion would be to try going through a full detail process. Claying, polishing, etc. See what improvements that makes on the surface.
You should be able to get it through them directly. Fwiw though, heres a fender I did on a Jeep. Obviously this isnt a permanent solution, but nothing will be if the plastic is faded this bad from uv exposure. It did last a few weeks though. And like black wow, Poorboys Trim Restorer takes very little product to achieve these results and will easily last the same amount of time.
W/ a quick swipe to show the difference.
After
Quick Reply: Ask GlimmerGlass
