Safest way to remove paint off of your car?
My wife was in an underground parking lot and trying to get out of a tight space and some guy was ‘helping’. She was worried about one side and he told her she was fine. However, this total ‘foxtrot’ idiot did not tell her she was about to hit a garbage bin on the other side. As my wife said, that’s probably the first time she’s so quickly told someone to ‘foxtrot’ off.
Anyhow, lots of green paint on the driver side corner of the front bumper. I looked on the Internet for various suggestions. I have some Scratch Doctor. It took off some paint, but just wasn’t doing the job. Similarly, Good Gone (a mild solvent and adhesive remover) removed some, but still not enough.
This morning I tried a strong mixture of Meguiar’s Deep Crystal Car Wash (bought it years ago) in hot tap water. The mixture was two cups of water and probably 3 to 4 tablespoons of detergent. I used a microfiber cleaning cloth and held it over the area like a compress. I kept the whole area wet, then gradually started putting more pressure on individual areas. It took five to ten minutes to get it off. I rinsed the area with lots of water, then worked over the whole area with Scratch Doctor and a clean cotton cloth.
Hey man,
Solvents usually are not going to "cut it" for removing paint transfer.
The safest way is to get a medium cut compound and a finishing polish.
First, put some of the compound on a microfiber towel and rub the area until all paint is gone, then follow up with the finishing polish to really bring back the gloss to full effect.
You might get away with just polish, but it doesn't have the cut level of a rubbing compound so it will take more effort.
I would not waste my time with a clay bar. If you use a fine grade clay, it will take FOREVER and is really ineffective. Using an aggressive grade clay bar will probably mar the area and while it may be more effective at removing transfer paint than a finer clay, it's still not going to be as good as using a polish/compound method.
http://www.youtube.com/watch?v=VByee3XcsTk
Anyone tried rubbing alcohol?
I've used it before to remove transfer and this guy in the video shows it going to work pretty good here.
