Detailed: My GS400 (before vs after)
Look how dirty that was...
hahaha..
Great detail...looks amazing..definitely should have gone with souveran!! lol...
i just got back to LA and my car was in the worst shape ever...
probably the same condition as your before with 3 months of water spots and etchings on the paint....yikes....
hahaha..
Thanks guys! I'm happy with the end result for now. Still planning to get a repaint eventually because I have lots of rock chips on my front bumper and part of the hood. I love this black color
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
hello there.
i have almost 99.5 perfect paint but i want it to look perfect no little clear paint marks. What can i used to take that away and make it look like that picture of the refection of the sc. i just wax cause im scared to mess anything up.![Uhh...](https://www.clublexus.com/forums/images/smilies/1387914497.gif)
let me know please
let me know please
![](http://img.photobucket.com/albums/v226/GSteg/IMG_1519.jpg)
![](http://img.photobucket.com/albums/v226/GSteg/IMG_0419.jpg)
![](http://img.photobucket.com/albums/v226/GSteg/IMG_0417small.jpg)
![](http://img.photobucket.com/albums/v226/GSteg/IMG_0373.jpg)
![](http://img.photobucket.com/albums/v226/GSteg/IMG_0372.jpg)
So bottom line, you need to polish your paint in order to get any kind of reflection. You're not going to get anything if the paint is dull because of swirl marks
Of course I have to use a machine (look at my previous posts
The pressure varies so I cannot give you a specific answer. The pressure you apply on an dual action buffer is different than on a rotary. Likewise, the pressure also varies depending on what panel you're doing. Not all cars are the same. You have to go by feel and best judgment.
For pads, I use light cutting pad to get rid of the swirls, following up with a polishing pad to remove any trace of halogram that the cutting pad may leave behind. It's finer than the cutting pad so the surface becomes smoother. Note that many manufacturers have different color pads. Not all white, orange, yellow, etc pads are the same. For example...X company may be using a yellow pad for heavy cutting while Y company may be using brown for the same purpose
very nice indeed, Its always a pain in the butt to work on black cars but your results are amazing.
Seems like the menzerna products are pretty good. I'll have to go try a bottle
now.
now.
btw that sc300 in the reflection is nice
Thanks for clarifying the death of the UDM.
Still, it has excessive vibration even when new due to its stronger motor. I tried using it while blkexcoupe was using my rotary and I couldn't even use it for more than 2 minutes before I had to stop. My hands were starting to tinkle and got numb really quick. I can't see any advantage of using a UDM if you know how to use a rotary, other than maybe applying wax. rotary is quicker, more effective, no vibration, and a blast to use as a sanding machine
However I do like the fact that the UDM is a lot quicker than a PC when it comes to swirl correcting.
StockGS400
01-28-09 09:21 PM
