wax whole car then buff off
Is it ok to wax whole car then wipe off. I will be using a cheap random orbital. i just get tired of changing back and forth to buffing bonett
![Agree](https://www.clublexus.com/forums/images/smilies/iamwithstupid.gif)
Some waxes will become VERY difficult to remove if left on too long and are better removed right after application.
Something like exp works very well when applied to the whole vehicle, then you can go back around and remove it all in one shot.
i should have waited and listened to you all. I did it in my garage last night with nu finish wax and it was a ***** to get off on the side i started first. leason learned.
Hacked CL to become a Mod
is 10 mins too long? i usually do segments of the car and then buff off the segments i did before while letting the ones i just did dry off
i drive the light colored car, so that can be forgiving
A major contributor to hard wax removal is the thickness of the application. Many people apply way too much wax. When this happens and it dries it is difficult to remove. If you have done this here is a tip. Reapply the wax to the area and the solvents in the wax will re-liquify the hardened wax and make it easy to wipe off.
Wax and sealant should be applied so thin that you can barely see the film on the surface. If applied like that you can leave it for a day and it will still come off easily. Any heavier application is just wasted product anyway so make it easy on your self and apply it very thinly with a foam or microfiber covered applicator.
If you prefer having waxes that you can leave on and wipe off after a while, consider getting Rubbish Boys OE. I put it on 2.5 hours ago and the swipe test still gets streaky due to the high carnauba content of the wax lol.
(My friend left it on overnight before and it was still wet
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
Todd@ProperAutoCare
Automotive Care & Detailing
02-16-11 07:38 AM
