Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
plastx isn't working on inside of headlight
Old 12-16-08, 02:28 PM
WDoherty
WDoherty's Avatar
Default plastx isn't working on inside of headlight
Meguirs plastx has always worked perfectly for me the outside lenses of my headlights. This time i had moisture in a headlight so i split it. There is a nasty residue after i dried it out in the oven. I use those blue disposable shop towels to polish and dry (they've always worked on the outside). Any recommendations. I was looking at what OLT was using in his "HOW TO" clean your headlights forum, but it looked like a wax?
Old 12-16-08, 02:47 PM
eyezack87
eyezack87's Avatar
He did use wax to clean his up. The only way I got rid of the minor staining on the inside of my headlights was with a true polish such as Menzerna FPII or M105 by hand. It helped but with the time I spent cleaning mine, it is much easier to buy another lens cover
Just do multiple shots of PlastX. It works but it takes a long *** time...
Old 12-16-08, 05:40 PM
UDel
UDel's Avatar
How did you get your headlight off to get at the inside of your headlights? Did you have to cut the black sealant and go through alot of trouble.
Old 12-16-08, 06:35 PM
eyezack87
eyezack87's Avatar
^^Its not that hard UDel, its just 250F in the oven for 5 min and slowly pry it apart. The silicon you can either pull or cut it when its nice and soft. It goes back to normal after so its all good
Old 12-16-08, 08:30 PM
WDoherty
WDoherty's Avatar
I actually found it impossible to split after 5min at 275 degrees, then the next day i tried 300 for about 7 mins and it came apart easily.
Old 12-16-08, 09:10 PM
eyezack87
eyezack87's Avatar
Well, you have to go slow. 5 min each round to be safe. I never put them in there long enough or hot enough to do at once. My friend did that and melted his housings a little so I was sorta scared after that haha
Old 12-30-08, 08:07 PM
WDoherty
WDoherty's Avatar
Update: I eventually had to get a 3m headlight restoration kit. Polishing even with a buffing wheel and drill got me nowhere. I had moisture damage on the inside of the lens. It had to be sanded in multiple stages down to a wet 3000 grit disc then polished. It was alot of work and isn't perfect, but very good.
chaose
02-14-18 10:50 AM
Badmittn
16
07-18-12 02:01 AM
chaiyang7
03-23-12 10:33 AM
Badmittn
07-25-09 07:48 AM
sputniknyc
05-14-05 10:15 AM
Quick Reply: plastx isn't working on inside of headlight
