Zaino Z16 - it has been the best one I have ever used. Not too shiny and slick and does not sling off your tires on your car - perfect satin finish that is slightly glossy.
I switch between Poorboys Bold n Bright and Optimum's Tire Gel. I'm sure I've posted the pics on here before, I'll have to try to dig some up.
I'm using the Poorboy's right now and am very happy with it. Only thing I've used that has given me absolutely no sling-off. I've used the Zaino in the past and have been happy with that as well but if I remember correctly there was a little sling-off at times. Either would be good choices IMO if you're looking for a semi-low gloss dressing. Neither are too glossy but can be a little brighter with a second coat.
Zaino does not sling - I am very picky about that and since my GX is white I would see it if it did. I apply it lightly with an applicator sponge from Griots Garage then go over it again after doing each wheel with just the sponge to even it out. Perfect after that!
