spider marks
Get a Zaino treatment on your car, whether you do it yourself or get someone to do it. There are a couple of topics in this area that will help you with Zaino, for example "product recommendations" or "zaino pics" which will give you hints on how to use it and what to use. A decent surface treatment will make all those spider marks disappear.
Poorboys kit:
http://www.glimmerglassdetailing.com/poudmpawfrit.html
optimum kit:
http://www.glimmerglassdetailing.com/opuldemapa.html
Correct, they're very close in price. This is just how it works out w/ the products included, thats all. You would use the orange pad thats included w/ the kit for the compound (on speed 5-6) and the white pad thats included w/ the polish (speed 4-5)
Be cautioned that polishing does remove a fine layer of clearcoat, and overdoing it will decrease the paint's lifespan over time. ALWAYS try the least abrasive method first! an Orange pad with the medium abrasive SSR 2.5 for just mild spider swirls on a new car is way overkill. Many imperfections like that can be removed with a white pad and fine polish.
http://autogeek.net/detailingtips.html is a great resource that I used to educate me on restoring the paint on my old 2000 Camry. Read up on basic ways to maintain paint, proper car washing technique, etc.
http://articles.autopia.org/articles...s-paint-1.html
Here is an additional good read.
Polishing is NOT a cure-all.
[QUOTE=ELL Y;4163508]Be cautioned that polishing does remove a fine layer of clearcoat, and overdoing it will decrease the paint's lifespan over time. ALWAYS try the least abrasive method first! an Orange pad with the medium abrasive SSR 2.5 for just mild spider swirls on a new car is way overkill. Many imperfections like that can be removed with a white pad and fine polish.
QUOTE]
The only vehicle I've been able to remove any noticeable amount of defects from using only a white pad and polish was on a subaru. Unfortunately, most paint surfaces are not that soft and a minimum of an orange pad is required for any type of correction. Using a glaze to help cover up imperfections, or using a polish w/ some fillers is another way to make those swirls less noticeable.
QUOTE]
Optimum is the polish i use to take off my swirl marks. but i only use the optimum polish with an orange pad maybe once every 6 months. every month or two i use a polish with fillers, i like one that Autogeek sells called "360 all in one". Its not as abbrasive as the optimum or poor boy polishes, it pretty much just fills in and "hides" the swirl marks. after the 360 i top it off with a sealant or wax. this will only last about a month or two before i have to do it all over agian.
