Which Trim Restorer To Use?
I have a 07 GMC Envoy for winter and the black trim on the exterior needs some lovin. There is a combination of smooth black rubber and hard grainy black plastic trim that needs some protectant and restoring back to dark black.
What do you guys recommend will work good for a variety of different surfaces and exterior materials. I've never used any type of trim restorer but these three seem to be popular.
Black Wow
Mothers Back to Black
Poorboys Trim Restorer
Thanks
Black Wow
Thanks
Black Wow
Thanks
Black Wow
Thanks
Greg @ Detailed Image
I use Poorboys Trim Restorer
Heres an example of what its capable of. (I use it in conjunction w/ a microfiber applicator fwiw)
Before (w/ just one quick swipe to show the surrounding damage)
After:
and heres a 50/50 shot:
After:
After:
After:
That is pretty impressive results on that jeep. How does Blackwow compare to the Poorboys trim restorer? I am going to be detailing a Volvo sedan and the lower plastic trim is pretty faded and gray and needs something to turn it black again. I would rather pay $15 for the Poorboys then $25 for the Blackwow if they are similar but if there is a big difference and the Blackwow is a good deal superior then I might have to go with the Blackwow. Someone also suggested CG Black Forever Gel.
All three of those products do work well. The Poorboy's World Trim Restorer - 16 oz leaves the trim dark and helps clean the surface. I would say the Black WOW Black WOW - 4 oz and the Chemical Guys Fade 2 Black - 13 oz are a little more permanent though. The Black WOW Black WOW - 4 oz is really an amazing product that would probably be my top recommendation to you. Just a pea sized drop is enough to do a really large area. It just seems to do an amazing job of bringing back the vinyl, rubber and plastic surfaces. The Chemical Guys Fade 2 Black - 13 oz is my go to product for wheel wells, engine bays, etc. Again all three work really well and are relatively similar products. Let me know if you have any questions.
Greg @ DI
I was looking for things like these for a time, thanks for these posts, Trim Restorer are really important, some people thinks that it's wastage of money, but it's wrong.
I never used Black Wow since Poorboys Trim Restorer always did what I asked of it. Dont forget that the Trim Restorer is also a larger bottle compared to Black Wow. So Trim Restorer is 10 bux less, but its also 4x the size, dont forget that
