Swirl-Free by hand?
#32
My method of washing and waxing the car is:
- Go wash the car at an open bay pressure washing gun.
-Dry with absorber
-Go home park in garage
-Rest for a while
-Apply The Ultimate Detailer from Meguiars
-Use MF pads from Walmart (cheap to buy)
-Apply Meguiars NXT Tech 2.0 wax to the whole car
-Wait one hour later then clean it off.
-Process takes about 3 hours
What you guys think?
-Dry with absorber
-Rest for a while
#33
I would suggest the 2 bucket method or if not possible in your situation then ONR.
I suggest you replace the absorber with a good drying towel.
Use a good applicator and that wax is not bad for OTC, if its easier and cheaper for you. I do not think that wax has to cure. We do not use that but read the back of it and check if it does. Highly doubt it though. Use a good micro to take off the wax, if it giving you problem coming off use some QD and your good to go.
#34
-Dry with absorber
-Rest for a while
-Dry with absorber
-Rest for a while
#35
I'd suggest doing a clay occasionally, maybe once or twice a year depending on your environment. Before you wax, try gently drawing your fingertips over the paint on your hood and if it doesn't feel as smooth as glass you need to clay.
NXT 2.0 is a sealant and does need to set-up before removal. Typically 20-30 minutes will do but your hour wait is just fine.
If you have a dark colored car you might need to pay special attention to the washing and drying materials used. Test your microfiber towels by rubbing them dry across an old CD and see if they leave any marring. If they do, they will likely cause swirls on your paint and you should replace them with higher quality.
#36
#37
#40
It'll slightly marr its just the basic design of it..
To help minimize that: dab or slap it on the car then lift up. Do not drag it, as it catches.. Use a Waffle weave..You'll never come back to the Absorber.
or you might just use the Absorber for convertible tops (which it works decent)
#42
Dysfunctional Veteran
Heh-heh, I understand, the Army has me on more painkillers than you can imagine (Vicodin, Percoset and Tramadol to name three). So I can sympathize.
