Wood Cleaning
meguiar's and mothers have some good all purpose or vinyl/rubber cleaners for the inside of your car. should be around $5 for a bottle.
you are not really cleaning the wood, just shining up the material they covered it with. if you keep it protected, your wood trim should do great.
![Lightbulb](https://www.clublexus.com/forums/images/icons/icon3.gif)
I too have used pledge and comparable spray cleaners/waxes w/ OK results. I had a problem w/ swirl marks and minor scratches on wood surfaces on my '98 ES300. I tried GS27, a scratch remover that has been heavily advertised as a cure all for scratches on exterior auto surfaces. To my pleasant surprise, the product did a great job removing the swirls/scratches in the wood surface and left behind a 'new car like shine'.
The GS27, IMHO, does a lousy job on the metal surfaces for which it is intended. But, on wood surfaces, I'd highly recommend it. Simply follow the instructions, rub the product on gently in a circular motion, and; the swirl marks/scratches disappear.
RX 300 & 350Z Guru
