What Wax do You Guys Use For Your Cars.?.?.?
★ I
When i wax i rarely het any swirl marks. I had a couple scratches on the lex and Zymol took them right out. One thing I would suggest would wax the area where you open then door or door handle, there were alot of nail marks there and it took it right out.
Concorso is super easy to spread thin. SN requires a bit more concentration but each are great waxes
Waxes have carnuba, which comes from a jungle plant, in them which gives them that deeper wetter look and it is generally more expensive to obtain and add a properly processed carnuba into the wax mixture which is why they generally cost more. The downside is waxes are mainly for looks and most don't protect as well or last nearly as long as a sealant but there are exceptions like Colonite 476S which lasts/protects longer and better then just about any sealant.
Many high end designer waxes are really just way overpriced and you are just paying for the name, fancy container/package the wax came in, smell of the wax, or percentage/purity of how much carnuba they claim is in the wax which is usually marketing BS. The designer wax itself looks/lasts/protects no better then say Poorboys Natty Blue, P21S, or Pinnacle Souvran. From what I have read Pinnacle Souvran is about as good as it gets for looks on dark colored cars and at around $80-$90 it is about the most you should pay for a high quality wax but bear in mind it still does not protect very well nor lasts very long when you compare it to a good sealant like Jeff Werkstatt, Zaino, Klass, etc. I like to have a base layer of a good sealant process like Zaino or JW and then if I want a little more depth/warmness I will add a layer of Natty Blue wax or if I want another layer of ultimate protection/durability and slicker looks I will add a coat of Colonite 476S.
