Engine shine with Tire Foam
5% Club. Killing it!!!
Can any negative issues occur using Tire Foam on the engine.. Last weekend i used Tire Foam just to shine the engine up and sprayed it everywhere. Can this Damage anything? The car drove fine on Monday but yesterday i replaced the battery due to not starting and the car sitting on and off for 3 years. I'm not sure if the Tire Foam contributes to the battery issues but today when the car is in drive it has a rough idle for some reason. Could this be the computer learning the new battery or do i need to clean the TB? Granted i haven't cleaned that in a very long time probably 3 years..
I usually use a rag with silicone to shine the engine up but wanted to try something new...
Thanks
Tony
Thanks
Tony
Many tire shine products are very oily and usually don't dry. If that is on your engine then you can expect a lot of dirt and dust to collect and stick to that oily surface. Depending on the product used, this could make your engine look dirty faster than ever.
As to running rough... If this stuff is causing an electrical leakage that is possible I guess. I'd wipe down the electricals with an old microfiber dampened with water and see if that helps. Look for any puddling of this stuff around the electrical connections and plugs/plug wires, etc. It is also possible that this stuff got into your air intake and could be clogging it up. Might effect the fuel mixture and make for rough running.
I agree w/ Jim. May not be great on belts if its not a "dry" product, and yea, can actually cause some accumulation of dust/dirt a little quicker.
But yea, I wouldnt say there was a high risk in using this and resulting in any damage, but anything is possible I suppose. I would guess coincidence, but as mentioned, try wiping everything down. Was the sputtering/rough drive there before you replaced the battery? I've never heard of a car having to "learn" a battery. Try giving the tb a cleaning like you suggested. I would treat these as independent issues, so go through a regular tune up type process to resolve the idle/drive. clean the air filter/tb, plugs if they havent been done in a while, etc etc.
Thanks guys for the reply.. I just finished cleaning the TB and MAF... The car idles high do to the TB and MAF cleaning until the ECU relearns itself.. I wiped everything down as best i could. The rough idle was there after i had charged the battery a few times yesterday and was not there last week? I will drive for a few days and see what happens..
Thanks
Tony
Thanks
Tony
You could use an all purpose cleaner like MegsAPC+ it leaves the plastics shiny.
