Haze on wood
How to remove wood trim pieces
Does anyone know how to remove the wood pieces.
I am wanting to recondition and refinish the pieces
to give it a richer, deeper finish. Mine are also getting
that dull haze look.
Or are this pieces actual faux veneers?
Wish I had an answer - I've got the same problem. It is subtle and only on the piece by the airbag. In certain lights look kind of "milky" in other lighting conditions it is not noticable.
I was thinking of using a very fine polish - like a plastic polish, but I would rather hear from someone else who has done it first.
I have a small patch of hazy wood trim too. Very small, but it is milky white in color. I don't know of how to get rid of it, but I use Armor All to shine the wood trim since it is made of synthetic material. It works well at giving you a clean shine, but whatever the Lexus dealership uses when they wash and detail your car is a lot better. I'm going to ask them someday what exactly they're using.
purple haze in my brain....
well, unfortunatly that haze is in the clear coat on top of the wood. You wont be able to 'clean' it off or lightly sand it off.
More than likely the prior owner tried to clean it with the incorrect chemicals, left them on too long and killed the clear coat.
These are actual wood veneer pieces, you can lightly sand and refinish.
Just wanted to bump this up to the top here again. I tried using a plastic polish and it started to make the wood look glossy rather than satin, so I stopped. I think the haze is a bit deeper. I would not want to try to refinish this myself, but would rather find someone in the local OC/LA area that had experience with it.
You have to remove the door panels to remove your trim. I cant remember how many nuts held it on (3 maybe 4). And "yes" it is real wood. Once you remove you door panels the back side of the trim is unfinished so you can tell its real.
The best product I have used is Klasse All In One ("AIO"). It works very well on the dark wood in my 04 ES - steering wheel, console, dials, door trim.
Some tips:
1. Apply just a little.
2. Use masking tape or be very careful about spillover to plastic (although this does not hurt much).
3. Let haze for 15-30 minutes.
4. Wipe off with an plush microfiber towel.
I don't suggest removing trim if you can avoid it.
Some tips:
