Scratches by door handle
Sorry for bringing back an old thread. But, I just bought the ScratchX 2.0, and is going to apply it behind my door handles.
There seems to be a good amount of fingernail scratches, will this product actually remove the scratches?
I've read some reviews, and after a wash the scratches will reappear...
Auto Detailing Master
ScratchX is a lighter to moderate polish that will in fact remove material to level scratches, however deeper scratches will require more work. I recommend applying a small amount to a microfiber towel that is wrapped around two fingers. Slide the towel behind the door handle and rub vigorously. Wipe away the residue and examine your results, repeat as needed until the majority of defects have been removed. I typically use a heavier cutting compound for this task as it is much quicker, but scratch x should make a solid improvement.
Yeah, I've notice some improvements. But, overtime & washing the car. Will the scratches resurface?
I mean, they are really just fingernail scratches. I once used water and a micro cloth and rubbed some out.
The paint will become scratched again by fingernails, but the scratches you removed will not magically reappear.
A polish (like scratch x) is a liquid which contains micro abrasives in it, and when this abrasive liquid is rubbed against your paint, it removes a fine layer of paint which physically removes the scratch as the scratch is just an uneven surface.
The only way the same scratch would reappear over time is if the product being used contained fillers that help to hide the defects. I do not believe scratch x contains fillers.
-Zach
-Zach
-Zach
-Zach
Any recommendations would be greatly appreciated.
