which is better? leather masters or leatherique?
i thought i should ask this... i often hear of people recommending leatherique but now im hearing leather masters being recommended also. so has anyone done a comparo? which one is the better product? also can you feel that much of a difference since our leathers are coated. thanks in advance..
never used leather masters, so i cannot give an unbiased opinion. personally, i think the leatherique system is designed for cars with older leather that has dirt embedded into the leather. the way leatherique works is by applying the conditioner on top of the leather and letting it penetrate into the leather to exfoliate all the dirt to the surface while softening the leather at the same time. after letting the conditioner sit in for a while, you clean the off the conditioner with the cleaner leaving your leather looking very clean and softer. i have used this stuff on a friends car and was absolutely stunned by the results, so i highly recommend this stuff as long as your leather is in need of some deep penetrating cleaning. definitely worth the money
I'm no expert.
But I've tried both more than once.
In my honest opinion, Leatherique demonstrated the most change in increasing the softness, and it seemed that the leather was rejuvenated. Leatherique only seems to work on a hot summer day, and I leave it in all day.
One negative of the product is that it can over soften the leather. (Which seems to cause more wrinkles.)
My 2 cents.
My 2 cents.
