Help! Polished Lip detailing failure.
I spent about 4 hours washing/clar barring/waxing my car yesterday and EVERYTHING went well except for when it came to polishing the lips on my recently purchases iForged wheels ( or rather attempt to polish.)
I've never ever had an issue with taking out hardwater spots or smudges on other polished wheels I've had in the past but these ones are a real pain. I have tried Mother's aluminum wax with powerball, Meguir's Metal polish that comes in the mini tub and also just some straight up elbow grease and the lip looks the same in terms of the smudges and water spots just a BIT brighter. Are there any alternative solutions? Or did iForged just put a sorry *** polish on their lips. Thanks guys!
Actually I just called iForged and they said that my specific wheel does indeed have a polished lip. He also suggested using some sort of buffnig machine to get them out. I also mentioned to him that the inner barrel design is pretty retarded for it traps water when you wash it so you have to get in there and either blow it out w/ an air chuck or use a towel and osmosis that crap out. He agreed. Ridiculous. Thousand dollar wheel and it traps water, wheels aren't hubcentric to Lexus's and the polished lip is harder than hell to maintain. Any other ideas guys?
im not promising this will work, nor am i saying this wont harm your wheels as i have never owned polished wheels, but P21S is a great company and their products are usually VERY safe. first, i would wash the rims with P21S Metal PolishingSoap. After that, i use P21S Finish Restorer. Then i top it off with Poorboys Wheel Sealant. i used this on my very expensive wheels and had amazing results (i have chrome) hope this helps.
if you want, send a pm or email to any one of our detailing vendors for their input as they are the true professionals. i am actually surprised none of them have chimed in yet. the stuff i told you about is what they told me and i got incredible results. best of luck and i certainly hope it works out for you
Use Glare Wheel Polish....its called "Knock out"
Its a multi step polishing process..it will effectively turn any polishing ball black within minutes....(thats getting your oxidation out)
If you're local to Fullerton I can show you my wheel, 18x10 and 18x11 Trafficstar wheels... I have a 6 inch lip in the rear....
Plan on a good 30-45 minutes each wheel..... but they are like a shiny set of new brass ***** =)
You can purchase Glare Products from Tuttle Click, Chrysler in Tustin.... ask for Dave Best.
Its the same stuff they use on airplanes and Air Force One.....
He initially gave me a bottle to test out.....and no I dont work for them or get any commission....or favors for promoting the product....
i have the same problem with my DPEs trapping water after every car wash.. i just use the sponge to soak up the water out, but i don't like these extra steps either..
i'm using P21S metal polishing soap with the poorboy's wheel sealant. my main problem was the excessive brake dust caked on my front lips. i still have haze after polishing, but it's a lot easier to clean and polish than the mother's metal polish i used before. like *Varsity64* mentioned, you might wanna try some P21S finish restorer also.. i really don't have enough patience to work on each wheel for 30+ minutes, but these products work quite well, you just might need some extra time with it.. gl..
Northern California Regional Officer
+ 1 for that polish as well as Mother's Billet Polish in a similar sized jar.
Most (not all) of the other products mentioned are not aggressive enough to get hard water spots out. For example NXT is great but not aggressive.
Try Mothers or Blue Magic, then follow up with the other wax/polishes like NXT for a super high shine finish.
