2010 Audi S4 New Car Prep and 3M PPF Install
Phantom Black/Black with Silver inserts
This was a new car prep that required clay and PO85RD, we finished with Collinite and Swissvax Divine. (unfortunately the car will be sitting outside for most of its life)
We also wrapped the front clip with 3m PPF.
The 2010 Audi S4 Key Specs:
Supercharger compressor
2,995 cc 3.0 liters V 6 front engine with 84.5 mm bore, 89.0 mm stroke, 10.3 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder
Premium unleaded fuel 91
Gasoline direct injection fuel system
16.6 gallon main premium unleaded fuel tank 13.9
Power: 248 kW , 333 HP SAE @ 5,500 rpm; 325 ft lb , 441 Nm @ 2,900 rpm
ABS
Brake assist system
Four disc brakes including four ventilated discs
Electronic brake distribution
Electronic traction control via ABS & engine management
Immobilizer
Center limited slip differential
Stability control
Multi-link front and rear suspension independent with stabilizer bar and coil springs
Day time running lights
Driver and passenger power heated chrome door mirrors
External dimensions: overall length (inches): 180.6, overall width (inches): 70.1, overall height (inches): 55.7, wheelbase (inches): 104.3, front track (inches): 59.9, rear track (inches): 59.9 and curb to curb turning circle (feet): 37.7
Electric foldable mirrors
Front fog lights
Headlight cleaners
Projector beam lens Bi-Xenon headlights
Luxury trim alloy & leather on gearknob, leather on doors and alloy on dashboard
Fixed rear window with defogger
Weights: curb weight (lbs) 3,990
12v power outlet: cargo and front
Air conditioning with fully automated climate control 2 and auto
Manufacturer's own RDS audio system with satellite, Disc Autochanger and six-disc remote changer CD player reads MP3
Cargo capacity: all seats in place (cu ft): 13.4
Computer with average speed, average fuel consumption, instantaneous fuel consumption and range for remaining fuel
Driver front airbag with multi-stage deployment, passenger front airbag with occupant sensors and multi-stage deployment
Recaro heated electrically adjustable driver and passenger seat with height adjustment, lumbar adjustment, thigh support, six adjustments and tilt adjustment electric, electric and electric
Height adjustable 3-point reel front seat belts on driver seat and passenger seat with pre-tensioners
Front seat center armrest
Two height adjustable active head restraints on front seats, three height adjustable head restraints on rear seats
Headlight control
Heated washer
Internal dimensions: front headroom (inches): 38.4, rear headroom (inches): 37.2, front leg room (inches): 41.3, rear leg room (inches): 34.2, front shoulder room (inches): 55.1, rear shoulder room (inches): 53.4 and interior volume (cu ft): 90.8
Products used:
Exterior:
Lusso AutoBathe
Uber Boar's Hair Wash Brush 7 inch
Swissvax Yellow Clay Bar and Optimum Instant Detail Spray and Gloss Enhancer
Einszett Spray Wax
P21S Finish Restorer Metal Polish (on the tips)
Menzerna PO85RD
Collinite Insulator Wax
Swissvax Divine
Wheels and tires:
P21S Wheel Cleaner Gel
Swissvax Wheel Brush
Uber Wheel Brush
Uber Spoke Brush
Swissvax Pneu
Swissvax Autobahn
Tools:
Infratech 5300
Flex 3403
The Uber Foam Pads (5.5inch)
Tons of "Uber" Microfiber Towels
Uber Drying Towels
Brushes
Gilmour Foam Gun
To the pics:
Before:
Dirty Wheels
Wash
Tom on the foam gun
Wheels being worked on
Debadged:
Engine shot:
interior shots:
Rear bumper film install (just partially installed to protect the top)
ABS
Brake assist system
Immobilizer
Stability control
Front fog lights
Headlight cleaners
Headlight control
Heated washer
Products used:
Exterior:
Lusso AutoBathe
Einszett Spray Wax
Menzerna PO85RD
Swissvax Divine
Wheels and tires:
Uber Wheel Brush
Uber Spoke Brush
Swissvax Pneu
Swissvax Autobahn
Tools:
Infratech 5300
Flex 3403
Uber Drying Towels
Brushes
Gilmour Foam Gun
To the pics:
Before:
Dirty Wheels
Wash
Tom on the foam gun
Debadged:
Engine shot:
interior shots:
Great prep!
I always enjoy a good detail
I'm highly interested on the Uber Boar's Hair Brush,
any details on it. I've been reading up a lot on it & I'd
like some feedback. Proper usage, and recommended
way of washing with it. Thanks!
Anything to keep the black car swirl free & washed faster.
they work great of course with the proper maintenance as you mentioned.
you have to wash them after each use and hang them to dry them.
you don't use pressure while washing the car. everything else would be the same as using a mitt or sponge.
