best way to remove 3m tape??
hi guys, i was wondering what is the best way to remove 3m tape, I tried adhesive remover by 3m and that took forever so i gave up, i would like to know what is the best way thanks...
I recommend a professional heat gun on a low temperature setting. Heat tape keeping a distance of 6-8 inches being careful not to overheat. Then remove adhesive and for whatever is left you can use either "Tarminator" or "Xenit" from Stoner. Follow up with a QD for any chemical residue that is left then wax or seal.
Dave
Dave
If the whole piece of tape is there, try rolling it off w/ your fingers. Might feel like your skin is going along with it, but this works best for me. Once you get the majority off, the 3M GPAC should take care of the rest w/ no problem
Ryanh1020
03-22-11 01:36 PM
