Costco Microfibers?
#35
Microfiber towels are a bit tricky. Just because they're expensive, doesn't mean they're better. Just make sure it's coming from a source you trust. I've seen towels go for $20 each....YIKES!!! IMHO, a quality mf towel should be in the $5-8 range. These towels will outlast the cheap ones for years, should be used on the soft Japanese paints, and will be easier to work with. Our current high-end mf towel comes in at over 600 grams, one of the softest and heaviest in the industry. We get our towels direct from the importer and bypass the middle men.
http://www.glisteningperfectionstore...els/Categories
Try out the GP MicroTowel for the paint...it'll be one of the best towels you've ever used...guaranteed.
If you guys haven't tried a specific glass towel, try our GP MicroGlass...it's a microfiber towel that has no nap so it won't leave behind any little fibers or lint on the glass.
In our case, you'll get what you pay for...I search high and low to make sure of that![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
About the GP Microtowel you mention, How many would I need for a typical car wash and how long would they last. For care, I learned from jfelbab about using Tide Free with my top loader (half of the normal amount) along w/ a few ounces of white vinegar in the rinse container. Also, he said to wash with hot rinse with cold water and dry in the dryer with the wrinkle guard cycle (https://www.clublexus.com/forums/aut...ml#post4899775)
I ordered some leatherique from detailedimage.com a few weeks back and picked up a DI Microfiber All Purpose Towel - 16" x 16" for $3.59. haven't used it yet, but hopefully it's high quality
#38
Now I'm doubting the microfiber towels I used to give my 2008 IS 350 (purchased new in Jan of this year) its first major detailing. My friend had just picked up microfibers from advanced Auto parts in a bulk pack. I also had my other friend's microfiber, but I'm not sure where those were from.
#42
Our GP MicroTowels are probably one of the finest towels on the market. Reason being the density of the towel, over 600 grams, the soft microsuede edging that mitigates scratching, and the ideal size 16X16. These towels should easily last you a few years and a six-pack should be more than enough to rotate for one car. They should be used for removing wax, applying and removing detail spray, light dusting of the interior, etc. You could use them for drying, but our GP Drying Cloth is better suited for that purpose. Hope this helps.
Thanks for the information from both of you regarding High quality Microfiber towels. I would like to be as comfortable as possible while cleaning on my 2008 IS 350 so will compare both of your products, prices, and promotions and decide between. I'm guessing w/ Chris's two choices, I would probably need the same amount of microfibers for a car and they should last just as long. I need to get some of the 303 aerospace too so might as well get everything at once.
Chris - when you say "final wipedown" - do you mean applying the final wax/last step product? (in my case, Meguiar's NXT Generation Tech Wax 2.0 - my 18-Ounce Liquid arrived yesterday")
the older, (I assume) lower quality microfibers I will keep for tasks such as these:
If there's anything else these older microfibers should/could be used for, please advise.
#43
#44
I use the costco ones all the time and they are great. I'm not sure when or why you would ever use a dry towel on a dry surface unless you are wiping off wax residue. I think it's more important to make sure the towel is clean, and that the surface is lubricated.
#45
F is for Fraud
I always dry using those microfibers and some Showtime detailing spray from Mothers'.
