Safely Reparing Light Scratches on Wheels
I have an 08 ES 350 with some light scratches on the sides of the spokes. They are the standard factory seven spoke alloy wheels. They look as if they are clear coated.
Is there any way to safely remove the scratches? They are light scratches and look as if they could be polished out. I am thinking about using the Kit heavy duty scratch remover (paste) in the yellow plastic container to remove the scratches but I am not sure if it is safe to use on the finish.
![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
Is there any way to safely remove the scratches? They are light scratches and look as if they could be polished out. I am thinking about using the Kit heavy duty scratch remover (paste) in the yellow plastic container to remove the scratches but I am not sure if it is safe to use on the finish.![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
I'll see if I can post some pics. I took some pictures today of the wheels and the scratches were nearly impossible to see from the photos.
These are the pics of the wheels. There are some scratches visible in the last two photos, but the camera does not do justice to the scratches visible to the naked eye.
Those should easily be polished off with Menzerna Super Intensive Polish
http://www.glisteningperfectionstore...sive%2C/Detail
If you really want to go all out and clean and protect your wheels, polish all wheels with Menzerna Super Intensive Polish, then wax using Rejex. This will help reduce pesky brake dust adhesion to the wheels.
http://www.glisteningperfectionstore...-polish/Detail
Also, by the looks of the inside of your wheels, may I suggest the ez detail brush. It will help clean inside the wheels and wheels wells with ease. Here's a simple kit that has everything you need to clean your wheels:
http://www.glisteningperfectionstore...sh-Kits/Detail
As for the swissvax wheel brush, is it bendable? I was wondering if it will bend to get behind the spokes inside the wheel.
http://www.glisteningperfectionstore...tail%2C/Detail
wyee99
Automotive Care & Detailing
11-23-11 12:57 PM
