what wax?
OK,
So I'd like a good wax, but not into paying super high prices for wax since I'm not sure (for me) that there is value in paying more than $50 for tub of wax.
Recommendations please. The car is 2006 IS350 with SGM paint.
I currently plan to purchase some Menzerna polishing compounds, but want to finish it off with a nice wax.
OK,
For protection you may want to consider a sealant over a wax. Sealants apply with ease, look great and offer much longer durability over a wax. Quality waxes usually offer a little more gloss but the extra protection a sealant offers is usually the best value on a daily driver. If you would like to use a sealant I would suggest the Blackfire Wet Diamond with Polycharger. It's extremely durable, super easy to use and looks outstanding. Best of all you need less than one ounce per coat so it's a pretty god value as well. If you need the most affordable option try the Optimum Poli-Seal, it's a great deal.
If you want you can layer a wax on top of a sealant for the best of both worlds or you can just use a wax. I would suggest either the P21S Concours Carnauba Wax or the Poorboy's World Natty's Red Paste Wax. Both options look great on lighter colors and will give you added depth and gloss. With your coupon code both waxes are under $30 and still give you top quality results!
As always save 10% off on these products with the coupon code 10offCl at DetailedImage.com. If you have any other questions please let me know.
Greg @ DI
Another suggestion. I've had very good performance from Collinite 845 or 476, Meguiar's NXT Tech wax or Meg's HiTech Yellow Wax #26. These are all usually available OTC and cheaply, although Collinite is somewhat harder to find. Most of these waxes are indistinguishable from each other in appearance in blind testing.
Hey guys, thanks for the input..... last time I polished and sealed, I used the poor boys products .... SSR2.5 followed by SSR1 and then the EXP sealant.
All in all, the stuff was decent... the sealant was a ***** to remove if I left it on too long. The one thing I didn't like about the SSR polishes was the amount of dust... but then again, it was my first time ever polishing so I'm not sure if this is normal or if there are polishes that dust less?
At any rate, a friend of mine has great success with Menzerna polishes so I figured I'd try those out... if the wax isn't a big issue, maybe I'll just stick with my poor boy's sealant but get new polish.
Also, Greg... how would you compare the PO83 to the PO85RD? Do you carry a 16oz version of either? I only see 32 oz on the site...which for me would last about 10 years....
Its going to be very hard to find a polish that doesnt dust. Menz will dust, Megs will, and just about every other I've tried will as well. Just a matter of how much, like you mentioned.
For an inexpensive wax, I'd definitely give carnauba moose wax two thumbs up. Does a very good job of deepening the appearance. And as Jim mentioned, 845 insulator wax and 476 Super Double Coat are hard to beat, although, I think you'll find that 476 may be a little tough to work with, as I've had some mention this.
Let me know if you have any other questions.
Just a tip on working with polishes. Polishes should be removed wet. Wax and sealants should be left to dry but polishes should not be worked until they dry. I find that I have no dust issues using nearly any polish. Apply and work the polish to a small 2'x2' area until it breaks down to a clear film then remove with a microfiber.
Where in CA are you located? I have Menzernas Polishes if you want. I bought the 32oz P0203S (medium polish on light cutting pad/polishing pad) and the P085RD (final polish on jeweling pad). I can give you 16 oz of each if you want. Just give me an offer. I'm in Orange County by the way. LMK.
http://www.glisteningperfectionstore...ster-gp/Detail
Thanks for the offer buddy, I'm all the way up in Camarillo so I'd spend more in gas driving down there!
