leather cleaning product??
hey guys what leather cleaning product have u guys used and experienced and works good?
i was gonna order some swissvax but the items r way to expensive!! almost 80 bucks just for the leather cleaner and leather milk O.o so i was wondering if u cl members have any other brands in mind that we can get in socal?
Zaino's leather cleaner (pump spray) works fine for me. No residues and wipes off easily. There is a mild leather smell that lasts a few days.
Once the leather is clean, I apply Zaino leather conditioner (cream) to moisturize the leather. The conditioner has a slightly stronger leather smell, but nothing to be concerned about.
Not in this cold weather. But in warmer weather yes.
In addition to routine cleaning, leather requires conditioning to replace oils lost through evaporation. (The smell of leather comes from these oils.) If these natural oils are not replenished, leather will eventually dry out, become brittle and crack. Here is the best product available to clean, protect and preserve your car's leather interior.
Leatherique Rejuvenator Oil![](http://i159.photobucket.com/albums/t158/zoomzoommazda5/classic-motoring_2082_5653181.gif)
Leatherique Rejuvenator Oil actually restores softness, beauty and strength to aged and abused leather. This oil is recommended for leathers used in furniture, automobiles, boats, motorcycles, airplanes, clothing, handbags, saddle and tack. It will not stain or discolor leather.
Leatherique Rejuvenator Oil contains no silicones or wax. It allows the leather to breath without any greasy finish or dust attraction. Once conditioned, leathers will remain healthy, soft and pliable for months.
Leatherique Prestine Clean![](http://i159.photobucket.com/albums/t158/zoomzoommazda5/classic-motoring_2082_5692943.gif)
This is the second half of a two-step leather maintenance system from Leatherique. With most leather care products, you clean the leather first with a cleaner then you apply a conditioner to keep the leather soft any pliable. The Leatherique system is just the opposite. You apply their conditioner, Rejuvenator Oil, first which conditions the leather and forces dirt and grime to the surface. Then you wipe the leather with Leatherique Prestine Clean cleaner to remove oils, salts and grime brought to the surface.
Leatherique Prestine Clean will not remove any conditioning oils that permeated into the leather during conditioning. It can be used as often as needed to remove dirt, oils and perspiration stains on leather and vinyl surfaces.
If you own a convertible with a leather interior, you should consider additional sunscreen protection. The best solution is to alternate between a leather conditioner and 303 Protectant. One month use a conditioner to keep the leather healthy and supple. the following month, mist and wipe the leather with 303 protectant to add UV protection.
