Removing Primer???
![Post](https://www.clublexus.com/forums/images/icons/icon1.gif)
Hello there....
During Car painting some primer got oversprayed in the engine bay on my carbon fiber engine cover.... what would be the best way to remove the primer??
thanks..
I dont think sanding will be necessary and difficult to remove on a thin cover like that. I would try using a clay bar and a dilution of an all purpose cleaner. You can pick up a APC from anywhere like walmart in the auto section or we also carry Meguairs APC here at Auto-geek. We also carry clay bars, you will probably need a good professional bar like our BLACKFIRE PolyClay II Detailing Clay or else the APC will deteriorate the bar too quickly.
Give that a shot, and if it doesnt work well come up with another solution. You will still need to scrub it quite a bit with the clay, it may not just come right off.
shadowman
Automotive Care & Detailing
08-03-11 10:32 AM
