I need help with my Carbon Fiber Hood
Hey..i bought a carbon fiber hood..and it has these gray spots in different places in the hood..and i was wondering if anyone know what i could do or buy to remove these nasty gray spots??..
The second picture looks like oxidation hazing. My old CF hood would oxidize if I didn't polish it regularly.
Typically oxidation can be removed with only a light polish, something like a white pad with Menzerna Super Finish on the Flex should be more than enough to remove the light oxidation.
http://www.glisteningperfectionstore...2C-dual/Detail
http://www.glisteningperfectionstore...hite%2C/Detail
http://www.glisteningperfectionstore...32oz%2C/Detail
As for the larger grey spot, that might need something that is a little bit more intensive. You can stick with the white pad, albeit a different white pad, but maybe change it up to something like Menzerna Power Finish. That should still finish clean but should have enough cut to take out whatever that spot happens to be.
http://www.glisteningperfectionstore...-Finish/Detail
Carbon Fiber heats up easily, so when you are polishing make sure to pay attention to your surface temps so you don't damage your clearcoat.
Hope that helps, good luck.
Take it to a good paint shop and have them prep it and apply few coats of good grade clearcoat,if you don't, it'll turn yellow ,even if you keep polishing and waxing
Stefan
Stefan
yea i might do that..cuz i bought the scratch 2.0 from walmart..and i used it,,the most of it came off..and the big circle in the middle didnt..
but the next moring...it all came back so i still dont knoe what to do,..
