Pre-Treating Products?
After two major snowstorms over the last two weeks there is still a lot of snow & salt on the roads here. I was wondering if there are products available that I can spray on areas of my car that have the most dried up salt/brine residue. See I'm still using touchless washes since its still cold and it doesn't totally remove the residue to my liking. I pre-treat my wheels with P21S just before I enter the wash and I want to do the same for areas of the body with another product. The only product I looked at was Tarminator but I decided not to buy it. I'm looking for something in an aerosol can or plastic bottle with trigger that I can just spray on the car moments before I enter the wash.
Greg @ DI
I have to second the suggestion for the P21S Total Auto Wash. That should loosen up everything that is on the paint before you give it a hearty rinse to remove as much as possible.
You need to be conscious of the total impact of the Auto Wash however. It is great for loosening up the dirt and grime, but it is also great for removing your wax layer. We use it as a prep for our details, so removing the wax isn't a big deal, actually it is a necessary step. So if you don't mind re-applying your surface protection then I think it would be a great choice.
Hmm, if thats the case, mix up a gallon of ONR QD dilution, put it in a pump sprayer (found at any hardware store), and pretreat using that. That should help make things easier for you guys with frozen pipes. I do that in parking lots when I haven't had time to wash for weeks before a meet. After, I just do a normal ONR wash and it helps cut down on marring
darksparkz
Automotive Care & Detailing
08-05-06 05:41 AM
