Removal of Wax Build Up
Back when I was working on a BMW showcar, I had to be very careful around these areas because if I lifted it, game over. The method I used was an APC, I used Optimum Power Clean, and a microfiber towel. I'd first spray some on, then spray some on the towel and using light pressure, remove it by rubbing it. It didn't do any damage at all
Take a wooden toothpick and gently run it along the edge of the film. You want to pull the toothpick towards you. The rest you can use a thin waffle weave microfiber and some spray wax or detail spray and gently run along the seams. You can avoid this by taping the edges of the film next time or using a wax that doesn't leave any residue behind.
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
Even though it isn't specifically mentioned as something it is good at, the Einszett Plastic Cleaner is absolutely fantastic at removing dried on wax. I remember Moe actually being blown away at wax he was struggling to remove with Tooth Pics and brushes and other methods literally wiping right off just from using the Plastic Cleaner and a MF towel.
http://www.glisteningperfectionstore...C-vinyl/Detail
Simply spray a little on a MF towel, and run it along the edge of your clear bra and it should remove the wax along the edge.
MikeE12345
10-06-11 02:24 PM
gassman
09-22-06 03:18 AM
