Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
Dried wax on headlights...
Old 03-08-10, 07:56 PM
lexusscturbo
lexusscturbo's Avatar
looks like etching, try the 3m kit
Old 03-08-10, 08:08 PM
MoeMistry
Former Sponsor
MoeMistry's Avatar
Originally Posted by 1UZ-GS
Here's a few close-up pictures for you guys.
1.
As you can see, it's on both driver and passenger side lights.
2.
3.
That does look like some sort of product that was wiped on and it's basically sitting on the headlights. What types of polishes have you used so far? That would be my first try. Have you considered claying it yet as well?
Old 03-08-10, 08:13 PM
ThomasGS4
ThomasGS4's Avatar
Well, I just tried polishing it by hand...don't even know which polish I should use, that's why I turned to you guys. As for claying.....I have no idea. lol
Old 03-08-10, 08:19 PM
MoeMistry
Former Sponsor
MoeMistry's Avatar
Give this polish a go. It's something you'll use for many purposes so it won't be obsolete:
http://www.glisteningperfectionstore...-Finish/Detail
Use one of our orange hand applicators or a mf polishing cloth:
http://www.glisteningperfectionstore...tor-ccs/Detail
http://www.glisteningperfectionstore...th-v1.1/Detail
Use your promo code and get 10% off. Hope this helps.
Old 03-08-10, 08:22 PM
ThomasGS4
ThomasGS4's Avatar
Ah ok fantastic!
Thanks for pointing me in the right direction.
Old 03-08-10, 08:40 PM
iKon_RX
iKon_RX's Avatar
i suggest claybar
Old 03-08-10, 10:16 PM
GlisTech
Former Sponsor
GlisTech's Avatar
I didn't see this mentioned, but are you sure that it is on the outside? Just want to make sure.
I would note the texture of the damaged area, and after polishing see if there is any difference. It could be a case that the plastic is etched due to some harsh chemical being used, and the damaged area is actually BELOW the normal surface. If that is the case, polishing might not help. So note the texture before and after and that might help us to diagnose the problem and the solution better.
Good Luck!
Old 03-09-10, 05:09 PM
edwinbong
edwinbong's Avatar
wow this couldve gotten ugly real quick. just always remember to go from the least aggressive approach then move onto the next step if it doesn't work.
Old 03-10-10, 07:53 PM
AU_EE
AU_EE's Avatar
What does it feel like if you drag a fingernail across the area perpendicular to the apparent "wipe" direction. Compare that to an unaffected area and describe.
Old 03-10-10, 08:16 PM
ThomasGS4
ThomasGS4's Avatar
I'll give it a try tomorrow morning.
Old 03-10-10, 11:18 PM
LexusJimD
LexusJimD's Avatar
Looks like there could have been an ammonia-based glass cleaner or some other chemical wiped on the plastic lens and left to dry.
A headlight restoration kit would solve the problem. The new Mothers one I've used on older headlights to restore them and it worked great!
I'd definitely try the polish first with the ball, but if that doesn't work, you'll need to use the restoration pads.
On further thought, looking at the chips on the front of the vehicle makes me think that if those lenses were "restored" with a cheap headlight product that adds a new coating, it could be that restoration coating is going bad -- but you can remove it with the kit shown above.
Old 03-11-10, 05:01 AM
ThomasGS4
ThomasGS4's Avatar
I think that may be my best bet right there. ^^
Hell, there's even a GS on the bottle!
Old 03-11-10, 09:13 AM
UberNoob
UberNoob's Avatar
i recommend you try clay baring first too
thats the safer method without removing the OEM protective finish on the lenses
Old 03-11-10, 04:47 PM
ThomasGS4
ThomasGS4's Avatar
Scratched my finger nail on it...smooth regardless if you scratch it vertically or horizontally, so it's not etching. I'm a little lost here since I'm getting quite a few opinions.
Old 03-11-10, 08:44 PM
AU_EE
AU_EE's Avatar
I would say thats good! Based on that I'd agree with edwin above and go through the options that have been presented, least aggressive first until you find success - clay is obviously pretty easy/almost no risk and you may already have it and is useful otherwise anyway; polish would probably be next IMO... if those fail, you could move to the restoration kit, etc.
Quick Reply: Dried wax on headlights...
