Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
Dried wax on headlights...
Old 03-07-10, 11:43 AM
ThomasGS4
ThomasGS4's Avatar
Default Dried wax on headlights...
Apparently, I have dried wax on my headlights and won't come off regardless of how hard I scrub. Should I wet sand them? TIA!
Old 03-07-10, 12:01 PM
tromly
tromly's Avatar
Wet sand and then use Meguiers PlastX, $ 5.70 at Walmart, does a great job ! Good Luck
Old 03-07-10, 12:22 PM
ThomasGS4
ThomasGS4's Avatar
Which sandpaper grit should I use? 3000?
Old 03-07-10, 12:44 PM
beachman
beachman's Avatar
Before you get into sanding, I'd recommend Griot's Garage "Dried on Wax Remover". You can also but some acetone at a hardware store & try that.
Old 03-07-10, 12:47 PM
MoeMistry
Former Sponsor
MoeMistry's Avatar
Wetsanding to remove wax????? Cmon guys. Try polishing it first. You can even use some goo gone or 3M General Purpose Cleaner.
Old 03-07-10, 12:51 PM
ThomasGS4
ThomasGS4's Avatar
Hmm...may have to check this out. Thanks for your input.
Forgot to mention...I polished them to no avail.
Old 03-07-10, 12:53 PM
MoeMistry
Former Sponsor
MoeMistry's Avatar
What wax is it? What polish did you use? How did you apply/remove the polish?
Old 03-07-10, 12:54 PM
MoeMistry
Former Sponsor
MoeMistry's Avatar
acetone may discolor the plastic on the headlights....not too many glass headlights out there anymore.
Old 03-07-10, 01:03 PM
ThomasGS4
ThomasGS4's Avatar
Lol...I meant to quote the part about the Dried on Wax Remover...I don't think I would use acetone.
Old 03-07-10, 01:17 PM
ThomasGS4
ThomasGS4's Avatar
Just talked to an auto detailing specialist, and he claims it's "UV Acrillic Damage" as opposed to wax. It's on both of my inner lights. (Note: I bought the car this way) Here's a picture:
Old 03-07-10, 03:59 PM
MoeMistry
Former Sponsor
MoeMistry's Avatar
That's simple too....that same detailer, if proficient and knowledgeable, should be able to polish or wetsand the lights properly. A closer-view picture would help.
Old 03-07-10, 06:01 PM
ThomasGS4
ThomasGS4's Avatar
Sorry...this was the only pic I had that would suffice.
I'll take another tomorrow.
Old 03-07-10, 07:51 PM
nthach
nthach's Avatar
Do the lenses look foggy or "faded"? Also, keep in mind that once you wetsand and polish a polycarbonate headlamp and unless a UV coating or periodic cleaning is done, you may need to redo the job again.
Old 03-07-10, 07:54 PM
ThomasGS4
ThomasGS4's Avatar
The headlights are crystal clear except for that one part - reason why I thought it was wax.
As I stated earlier, I will take a close-up picture tomorrow.
Old 03-08-10, 07:54 PM
ThomasGS4
ThomasGS4's Avatar
Here's a few close-up pictures for you guys.
1.
As you can see, it's on both driver and passenger side lights.
2.
3.
Quick Reply: Dried wax on headlights...
