Waxing by hand help
Waxing by hand help
I just got a black 07 IS250. It has a decent amount of light scratches which I know they all wont come out. I know the best way to deal with them are by using a PC. But im not going to by one, just rather do the best I can by hand. Im willing to wax 3xs a year, spring, summer, fall. I have been using Meguires NXT 2.0 which looks awesome. But it doesnt seem to last very long. Also would you recomend using a meguires swirl remover by hand before waxing? or am i just wasting my time with that?
With that said, you can only do so much without the proper tools. If you want to minimize the small-medium stuff and apply a good wax that lasts longer than NXT and can fill some of the smaller stuff, try the einszett line.
Here's a good kit that has everything you'll need:
http://www.glisteningperfectionstore...Wax-Kit/Detail
Let me know what you think.
Mequires line of waxes do not last long or protect all that well. If you want something that looks good and lasts a long time and protects very well try Collinite 476S. I use it and it is excellent. Just put it on and take it off, I get several months protection out of it. Klass AIO, Jeff Werkstatt, and Zaino are other sealants that last and protect for a long time.
Regardless of which wax or sealant you use, longevity depends largly on surface prep. Just like painting a house, if you don't prep the paint first, adding another coat won't last all that long.
First, I'd suggest washing and claying the paint. Then, depending on your energy and the level of marring in your paint, I'd probably recommend ScratchX. If the paint is very bad you might try Ultimate Compound. You might want to do this in stages as it is quite difficult by hand. Maybe just do a couple panels at a time.
Once you have prepped the paint properly I think you will notice a lot longer life from your wax or sealant. You will also see a marked improvement in the appearance of your car.
Also, if you aren't going to buy an orbital, I'd highly recommend you go with a strong scratch remover/paint correction products...like Meguiar's ultimate compound. That's the only thing I used that would deal with minor scratches by hand...
Having said all that I did go and buy a Porter Cable 7424XP. Best $125 I've ever spent. Makes paint correction so much easier.
the carnauba based Collinite 476S fills minor scratches fairly well and does provide a very good shine and protection for quite a long time
ive been using it for over 2 years and been happy ever since
ps. it rains a lot here in vancouver, more than in Seattle
so i really do put it through the test and i smile everytime after waxing it even if it starts raining
Yes you can apply Zaino by hand. I would recommend claying and polishing your car or having someone polish your car before you apply Zaino to get your finish looking perfect. I have never tried Zaino polishes but from what I hear they are just mild polishes and there are better ones out there for less money. Before you apply Zaino you should do an alcohol/water rub down or wash it with a soap made to get rid of wax residue to get the surface completely clean and free of polish/wax oils because they may affect Zaino adhering to your paint. Many will tell you you are going to need a bunch of different products from Zaino and spend a bunch of money to get good results but you don't. All I use is Zaino AIO, Z2, and for applying between coats Z8 if you want. It leaves the finish looking great and protects for a very long time.
I use Zaino and I like it. However, I don't like their paint correction line that much.
http://www.glisteningperfectionstore...-Finish/Detail
I guess at the end of the day, you gotta come up with a routine that makes sense for you.
IMHO, time is something you can't gain back. The results you'll get with 4 hours of polishing by hand vs. by a machine will be night and day. Measure twice and cut once. I'd hate to see you spend so much time trying to get where you want to go and only be disappointed.
If I remember correctly, AIO is a polish/wax. That product won't remove scratches, it might fill them and make them less visible. If you want a true polish that legitimately removes light swirls and scratches, then you'll need something like Menzerna Power Finish.
ZIAO is more of the base coat/layer for the Z2 or Z5 to adhere to. It has mild cleaning and polishing abilities but I use it more as just a base for other Zaino products. Z2 or Z5 may not adhere to your finish unless you have ZAIO on it or some other Zaino product on it so it is essential. If you have alot of swirls and scratches especially if they are deeper I doubt it is going to do much to get rid of them especially if you are going to be polishing by hand. I do like ZAIO though. I put ZAIO on first, then a layer or two of Z2. I only have to put ZAIO on once a year and then follow Z2 every 3-5 months, between washes I put Z8 if I want extra protection/gloss. I would say get the ZAIO and (Z2 or Z5 they are very similar) and optionally Z8 and try and see if the ZAIO gets rid of the swirls/scratches. If not you still have the ZAIO to use for the base Zaino coat and can just get a more aggressive polish to get rid of swirls/scratches.
I had a PC7424 and didnt like using it. The polish would splatter all over the place at times. Plus it was very difficult do use the PC on the doors and bumper. Its fine for your trunk, hood and roof. But any other part of the car its a pain. I ended up messing up some of the paint on my trunk as well. So I gave up it and sold it. I know using the PC is the only way to truely correct scratches. But i dont have that kind of time and dedication. One day if I run across a good detailer in my area that knows what hes doing ill pay to have it done. Until then I just want to wax by hand and do the best I can. So any help on products id appreciate.
Here's a very simple kit that will give you excellent results by hand. It was designed for clients like yourself in mind. Easy to use, simple three step process, and great results. Awesome price too
