Which Buffer - Porter 7424...??
How does the PC 7424XP stack up to the Griots Garage 6" Random Orbital (http://www.griotsgarage.com/product/...m+orbital.do)?
I'm looking for an entry-level polisher that would be effective for swirl and scratch marks on my black LS. Both products seems to be priced about the same, but the motor sizes are very different. 4.5 amps for the PC and 8 amps for the Griots. It appears that the Griots is more heavy duty and has a better design (handle rotates and provides more direct overhead leverage). Other impressions or thoughts?
I always see that the guys from Detailer's Domain use the Makita... is there a reason for it? Do you guys think it's better than the flex.
And on another note, if money is no object... what is the best (the best of the best) buffer you can buy? I'm thinking about getting me one pretty soon.
I own both the Makita 9227c and the PC7424. I seldom need to use the Makita and prefer to use the 7424. I don't work on cars that need much correction and keep my own vehicles in top shape so a rotary is not the tool of choice for me most of the time.
There is a new MF pad system nearing the market that will potentially make tasks only suitable for a rotary a breeze with a PC so I'd hold off till spring to decide which you really feel you need.
The rotary is not as forgiving as the DA and it is fairly easy to cause marring/holograms. The DA, while it takes longer to correct, it is much safer. My DA also seems to finish up better than my rotary. On those vehicles where I did need the rotary, I find myself doing the final jeweling with my DA to achieve the results I want.
The new MF pad system promises to make the DA highly effective for the heavy lifting as well as the final polishing so I'd recommend you keep an eye on this technology for a few months and make your decision after some more users have a chance to comment on their results. It looks very promising from what I see in the following thread.
Here is a link to the MF system I'm talking about: http://meguiarsonline.com/forums/showthread.php?t=46309
Flex Packages
DI Packages Flex XC 3401 VRG, Meguiar's Polish and Hydro Pads
DI Packages Flex XC 3401 VRG, Meguiar's Polish and Hydro Pads Starter Kit
DI Packages Flex XC3401VRG 2 Step Menzerna Polishing Package
DI Packages Flex XC3401VRG Advanced Package
DI Packages Flex XC3401VRG Starter Package
DI Packages Flex XC3401VRG With Custom Flex Bag
Makita Packages
DI Packages Makita 9227C-X3 Advanced Kit
DI Packages Makita 9227C-X3 and Meguiar's Polishing Starter Kit
DI Packages Makita 9227C-X3 Starter Kit
If you have any questions please let me know I'd be happy to help!
Greg
I have an old Black & Decker Polisher / Sander. It runs at about 2400 rpm's and it has served me well for years for minor sanding and car buffing. That said, I recently bought a 2010 RX 450h...BLACK. (What the heck was I thinking...?) I've been thinking about getting a professional buffer and it seems like the Porter Cable 7424 is a decent unit. Any recommendations about this unit or any other that would work well? ![Confused](https://www.clublexus.com/forums/images/smilies/confused.gif)
The machines being discussed and their descriptions is very good. The vendors here know their stuff. Mine was a purely economical decision. I picked up two Porter-Cables cheap. I put a large backing plate on one and a small plate on the other. Too lazy to keep changing during a detail. I haven't seen a Flex, but the description interests me. So does the cruise control of the Meguiar's.
This is my opinion, others please correct me if you feel I'm wrong, the obsidian black or more correctly the clear coat is very soft and it swirls easily. Start with a high quality car soap , clay the finish and gently polish then wax it. I use Meguiar's M205 with great success. If you have to correct some dealer instilled mess, try Meguiars Ultimate Compound (or something more gentle). Follow that up with M205. Do a test spot before proceeding to the whole car.
The way you wash it from now on will make a huge difference in the long run.
Enjoy your new RX.
babaliont
Automotive Care & Detailing
24
06-19-18 10:25 PM
Alexus_300
03-21-07 06:51 AM
