Last edit by: IB Advertising
Browse all: Cleaning and Detailing Guides
- How to Remove Swirls in Black Paint
Step by step instructions for do-it-yourself repairs
how do i remove water spot on black paint?
So I got water spot from the sprinkler like 3-4 days ago and I wasn't rush to clean off. I just left them there for the last 3-4 days. I thought I quick wipe would clean them all off.
This morning I did a car wash and then use a micro fiber towel to clean off the water spots from 3-4 days ago. Now They obvious spots were off but it still showing the subtle spots. My car is black and it's showing very obvious when looking close. I can't get them off no matter how hard I rub when dry and wet soft water micro fiber cloth.
Any advise would help a lot and I appreciate it.
My friend said that a body shop and buff it off but I searched and sometime it may need a wet sand to take off the clear coat. These spots on my car are like serious cuz I can't get them off no matter how hard I rub.
Here's what I use to take out the swirls in my paint. I'd assume it would be safe to use to remove the water spots aswell.
http://autogeek.net/wolfgang-porter-...l-remover.html
It's a lot of labor on your end. But for the price of the kit you could pay someone to do it for you. But buying the kit lets you keep your paint looking swirl free...I know how important that is with a black car ; )
I'd be surprised if you need to sand -- I grew up in FL, and the water there is as hard as concrete. You learned VERY quickly not to park near sprinklers that were drawing from a well, that's for sure.
Have you tried a vinegar/water spray? Often that's enough to eliminate water spots. If not, like eyezack said, buffing a car is usually enough to remove the spotting.
i just mist spray some Turtle Wax Quik Detailer and wipe with a microfiber, and once i start, i typically just do the entire car. lol! water marks shouldnt require any sanding, especially if it was just there for 3-4 days.
thx everyone for the comment. I'll try vinegar tomorrow. So just spray vinegar lightly on it and wipe it off with soft water then wax it up? or should i mix the vinegar with water? If this don't work then I'd just bring it to body for a buff.
I've tried many wash products, but this stuff is the best for removing spots:
http://www.meguiarsdirect.com/produc...p?T1=MEG+M6201
I'm not sure if it's sold in stores, but it's available oline. If the spots are very stubborn, you may have to clay the areas affected.
For the future if you don't want to deal with stubborn water spots make sure you have a few coats of a good sealant/wax on your car. Water spots won't adhere well to a finish with wax/sealant on it and are much easier to remove. I would highly recommend Collinite 476S, Klass AIO, Zaino as all of them last a very long time and provide very good protection.
Also remember to thoroughly wash(preferably with dawn or something stronger then a regular car wash) the car after you apply vinegar or polish it as they both will strip the wax/sealant on the car and most sealants/waxes will not adhere properly if their is vinegar or polish residue/oils on the cars surface.
I highly doubt this will make any difference. I have probably used more waxes and sealants than anyone else on this board and all act the same under organic compounds. You might have longer durability but thats about it in terms of protection. I'm waiting for nano tech to enter the market here
Very likely mineral deposits. After they have dried they are difficult to remove. What I find that works well is to soak some cotton towels in white vinegar and let them sit on the spots for a few minutes keeping them wet with added vinegar. This should re-dissolve any minerals and take them off.
Be aware that this will compromise any wax or sealant on the paint so you will need to redo that.
You could also try clay and/or a polish but that would entail a lot more work. A cleaner wax would also probably work and as you will need to rewax anyway, it is another option.
Lastly, depending on the contents of that water, you could have paint etching. That would need a polish to remove.
Good idea to carry a bottle of Quik Detailer and a few microfiber towels in your vehicle for just these events.
