Turtle Wax Leather Conditioner
I was wondering if Turtle Wax Leather Conditioner would be safe to use on the leather of my RX300? Will it change the color of the leather? I think I've read of other people on this forum using it, but I wanted to make sure before I use it. I know it's not anywhere near Lexol cleaners but it should do for now. I've been using Meguairs for a while and figured I would try this.Thanks in advance.
I agreed with JetFire on the use of that brand, alot of leather being used in todays automobiles has a top coating. Some leather can be either Semi-Aniline, means the Leather is dyed and a thin coating is applied for protection or Pigmented means leather is typically less expensive showing more defects, but is coated with a thick layer of colored pigmentation. Many leather conditioners, if used on this coated leather, will not penetrate the coating to allow the conditioning oils to reach the leather. Here are some products to consider for treating these types of leathers are listed below and if you're not sure if your car's leather is vinyl coated, check with your car dealer or with the manufacturer. Also with some members here at Club Lexus.
Blackfire High-UV Leather Conditioner
Collinite Leather and Vinyl Treatment No 855
1Z einszett Leather Care "Lederpflege"
Leatherique Restoration Products
Optimum Protectant Plus/Leather Protectant
Thanks for the help. I already bought it so I'm going to give it a shot on a small portion of the leather that isn't visible (ie, under the headrest).
It surprisingly, looks fantastic.
The leather is soft to the touch. The color is still the same.
It's a win in my book. Only down side is the smell, definitely does not smell good like the Meguiars but it does the job much better.
Thanks, for asking!
Once, I finish this bottle of conditioner in a few months, I'm dying to try the Optimum Leather Protectant, and the Lexol Quick Wipes.
![Woohoo](https://www.clublexus.com/forums/images/smilies/woohoo.gif)
Thanks, for asking!
superpocky
Automotive Care & Detailing
29
09-08-05 11:38 AM
