Wood Trim Looking Sad
Any pictures of it? A light polish like Blackfire Gloss Enhancing Polish should work for you if it has a clear coat on it.
Hey Guys!
Theres a huge lack of information on this topic but I think I have gotten a good feel for this since I just did it now.
1. I removed the trim for the car and washed it with a drop of dawn and water using a squirt gun.
2. I then applied the polish to my pad and start buffing with my DA. It was my first time using my DA and I was a little nervous so I stopped every minute to check if I did damage. Don't be afraid to crank up your DA if you aren't getting the proper results. I used a cutting pad by the way!
3. I sprayed the trim again with water and soap and wiped the polish off. Then I took wax and put wax carefully with my finger on the trim.
4. I bought an aerotect clearbra for the console to protect it forever!
Now I am on the waxing part but looks a lot better than before...I could have buffed a little more but I was using a cutting pad and heard this trim has only a thin layer of clearcoat.
