Tire Marks On Leather Seats
Firstly, punch yourself repeatedly in the face for putting a tire on leather! Clean yourself up, sit down and think about it. Then punch yourself a few more times.
After that, try using your favorite leather cleaner/treatment you normally use it should come off fairly easily, assuming the leather is not damaged past the dye/protective layer. A mild soap like Woolite is also good for cleaning leather.
I would suggest using a quality leather cleaner and conditioner like the Leatherique Prestine Clean and the Leatherique Rejuvenator Oil. It's a powerful combo that really helps deep clean the leather and leaves it looking great. If it's a really stubborn stain sometimes I spot treat stains with the 303 Cleaner & Spot Remover. If you have any questions please let me know.
Sorry to hear this happen to you vangis350, try our Optimum Power Clean that packs a powerful punch, yet it’s gentle when it needs to be. Clean everything from the engine and wheels to the leather and dashboard with one product. Optimum Power Clean can even be used on the paint to dissolve bugs and stubborn contaminants. For many jobs, you can simply spray it on and wipe it off. Then protect it with Optimum Leather Protectant.
I have the same problem
Thanks
Nearly all automotive leather is painted and clear-coated (Protected leather) . When it gets stained, it is vital to attempt removal ASAP. The longer the stain remains on this surface the deeper it will migrate into the clear-coat. Once it has migrated into the clear-coat, you will not able to remove it via cleaning. The process will then become one of restoration, which is definitely not a DIY.
The best advice I can offer is to initially try removing the stain as soon as possible using the CHAT method.
C=Chemical cleaning solution
H=Heat (Use a moderately hot cleaning solution)
A=Aggitation (it is ok to use a soft nylon brush to agitate the solution on the leather to maintain a foamy mix)
T=Time (be sure to generate a lot of foam and let the foamy mix dwell for a few minutes but not dry before wiping up.
I'd use a strong leather cleaner (e.g. Leather Masters Strong Leather Cleaner) mixed with some hot water. I'd use a foam sponge and squeeze the applicator several times to generate a lot of foam. Gently, but briskly, massage the stain but avoid scouring the spot. Let the foamy cleaner mix dwell for a couple minutes and wipe it up with a white cotton towel. Examine the towel to see if the strain is coming up. Repeat as needed. When the white towel is no longer showing signs that the stain is being removed, this is as good as cleaning will safely make it. If the stain is still evident see a leather restoration specialist.
If you wish to avoid stains in the future use a leather protectant (e.g. Leather Masters Protection Cream, LTT LeatherGuard, LTT Auto Ultra Protect). A leather protectant is a fluorocarbon sealer. It will form a barrier between your clear-coated leather and any future stains, dye transfers, etc., making clean up effortless. I consider these protectants mandatory for anyone with lighter colored leather.
S1aristo
Automotive Care & Detailing
09-09-08 07:54 PM
