Paint chips
What is the best way to paint chips? I want it to look like factory paint. But when you use the touch up paint with the included brush, it usually leaves a little bumb. Can an airbrush be used to fill the chips?
I want it to look like factory paint..
However, you CAN make it highly unnoticeable with a brush in touch-up, if done right, where only you will know, unless someone were to examine it up close. Of course, the smaller the chip, the easier it will be to hide the repair.
When you're talking air brush etc. and spot-in blends, then that's more involved ( the clear has to melt-in" using additives so as not to leave a halo) and more $$$, and even then, it would take a lot of experience with color matching and blending to make the chips look like they weren't there.
It's ( touch up w/ brush, Langka etc.) not a panacea, but will save you hundreds of $$$ over a spray repair.
