Automotive Care & Detailing Discussions on washing, waxing, polishing, detailing, cleaning and maintaining the beauty of your Lexus.
White car is turning yellow!
Old 02-15-11, 04:26 PM
kikcaffine
kikcaffine's Avatar
Default White car is turning yellow!
EEK, my Pearl SC300 is turning yellow in some places. What can I go to reverse this and make it white again?
Old 02-15-11, 05:13 PM
97-SC300
97-SC300's Avatar
Picture is worth a thousand words... post one up.
Old 02-15-11, 05:16 PM
LiCelsior
Retired
LiCelsior's Avatar
claybar is the simple solution.
Old 02-15-11, 07:42 PM
kikcaffine
kikcaffine's Avatar
Will do first thing tomorrow morning
Tried, didnt make a difference it didnt seem.
Old 02-15-11, 07:48 PM
kikcaffine
kikcaffine's Avatar
You can sort of see the driver fender is discoloring, Ill get some high rez pics tomorrow before work.
Old 02-16-11, 05:34 AM
Infamous 1
Infamous 1's Avatar
Try a DA polisher with light cutting compound and pad to match.
Old 02-16-11, 05:51 AM
kikcaffine
kikcaffine's Avatar
Old 02-16-11, 06:52 AM
PaPaHoFF
PaPaHoFF's Avatar
going to have to polish/compound. Seems to be your only option.
Old 02-16-11, 07:07 AM
kikcaffine
kikcaffine's Avatar
Would wet sanding fix it? At this point Ill spend the money to have it done professionally, but I just want to know if its something that can be cleaned or if its too far gone.
Old 02-16-11, 07:15 AM
IXI187IXI
IXI187IXI's Avatar
you sure its turning yellow and just not a mismatched paint job? i mean it is pearl paint and you get different colors under different sources of light (ie actual sunlight vs artificial light)
was the drivers side ever repainted at some point?
Old 02-16-11, 07:22 AM
kikcaffine
kikcaffine's Avatar
I dont believe so, the door isnt doing it, its only the top half of the fender in the front and the bottm half of the rear, its like its got a point where it starts fading.
Old 02-16-11, 07:46 AM
Angelo
Angelo's Avatar
Sorry to hear this, it could be a few combinations of things happing to it. Fall out from the past, it was repainted in the dealers yard ( I see it all the time at my local Lexus dealer back lot ) Maybe try a compound to see or see a good paint shop or shops to see what they would say.
Old 02-16-11, 08:44 AM
IXI187IXI
IXI187IXI's Avatar
you might want to check into it. im going to say it was a bad paint match imo.
Old 02-16-11, 09:02 AM
97-SC300
97-SC300's Avatar
Initially I was going to also recommend a clay bar....but as I expected, looking at the pics, the yellowing is very panel specific. If it was really road contamination, the yellowing would be all throughout the car, but it seems to be pinpointed on the panels you posted.
The BEST you can do now, is still try to clay the whole car and at least do a 2 step paint correction hitting it with an aggressive compound and doing a polish. If it doesn't help, then you have a bigger problem that is beyond what a detail can do for your car.
Old 02-16-11, 09:12 AM
kikcaffine
kikcaffine's Avatar
Im going to try to get some pictures in the sun of it, you can really see it then.
Dang.
Quick Reply: White car is turning yellow!
