Getting in deep........
Keeper of the light
I'm using Gold Class leather cleaner, conditioner lotion on my black leather and it is cleaning the surface very well........ however inside the grooves of the leather the gunk still remains. It's obvious on black leather, more so than any other color.
What will clean inside the grooves of the leather without scratching or wearing the surface out? Flat pads and microfiber towels are just not reaching in there.
Keeper of the light
This is what I'm going with by recommendation of others.
http://www.detailersdomain.com/swiss...therbrush.aspx
1JZ Single SC400
Compressed air on low setting with do the best, if you have it. Just spread the portion of the seat apart with one hand and spray with the other. Make sure you keep your mouth closed.. No telling what might fly in there.
Another great detailer secret.... use of compressed air.
You might also try a dedicated leather cleaner before applying the protectant. Optimum Power Clean is about as strong of a leather cleaner as you can use with out fear of damaging the thin protective coating over the leather.
Gently spread the seam apart and use a soft toothbrush, I've also got a Meguiars slide lock detail brush that works well too. It's meticulous work but worth it when it's done.
j stuff
Automotive Care & Detailing
26
01-29-23 09:52 AM
krava
04-11-13 10:23 PM
