Headliner help
Headliner help
I am wondering is there a good way to clean the pillars and headliner in my car? I left my windows down a little bit when it rained and the pillars steam to be stained? Any advice would be greatly appreciated it.
thanks
Adam
thanks
Adam
There is a product called Prep-Sol 70 by 3M that works wonders on removing stains and gunk from headliners and soft suedelike materials. Usually available at paint shops, it's another option. IF YOU USE THIS, WEAR GLOVES AND DO IT OUTSIDE. It contains a good amount of xylene, which is not really great to breathe (hence the do it outside part).
Big Mack
go buy a Mr. Clean magic eraser, trust me dude, just go buy it. Ive cleaned 2 of my cars headliners with them and its excellant and cheap. Just bring a bucket of warm water out to the car with you to ring it out often. Ring it out til its damp then in short light strokes in the same direction rub the problem areas.
So do I spray my headliner with 303 Cleaner & Spot Remover and then use mr Clean magic eraser to clean it?
And is the eraser that we are talking about?
http://www.mrclean.com/en_US/magic-eraser.do
I cleaned my headliner the other day using Folex and a terry towel. Spray the folex on the towel generously, then rub in one direction. Got rid of the dirt so quickly, I started doing the entire headliner. Took about 10 minutes and it looked great. You never want to get the headliner too wet or it may "delaminate" from the roof. The lexus headliner seems pretty thick to me though so may not be an issue. I don't like the magic eraser for this since it will spot if you rub it in a spot too vigorously. They are good for getting dried wax residue off of plastics and vinyl though...
Angelo, did you mean a steam cleaner? I thought it was bad to use them near SRS (airbags) for the most part?
Big Mack
Big Mack
